LG 42PT350R clicking problem fixed but still doesn't turn on
  • buchman
    • Aug 2015
    • 283
    • greece
    Replaced a few igbts on ysus and zsus and now the clicking stopped, also the voltages VS and VA are ok. But, when I connect all boardes together it burn out one of the igbt on the ysus.
    What I came up to is when I disconnect the ribbon cable between the zsus and the T-CON board, it doesn't burn out the igbt on the ysus.
    I know there should be 15V on ysus/zsus/t-con but I am not getting it. All other voltages are ok.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: LG 42PT350R clicking problem fixed but still doesn't turn on
    Are you running it without all the Ysus screws put back in which I think causes problems.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Originally posted by dick_barton
      are you running it without all the ysus screws put back in which i think causes problems.
      +1
      • buchman
        • Aug 2015
        • 283
        • greece
        You are serious or it's a joke?
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Very serious. We don't joke about things like that when someone asks for help.
          • buchman
            • Aug 2015
            • 283
            • greece
            How can it make a difference?
            • buchman
              • Aug 2015
              • 283
              • greece
              Didn't help.
                https://www.badcaps.net/forum/showth...ews#post798963
                • freakaftr8
                  • Oct 2012
                  • 3743
                  These boards have floating grounds. This is not a joke. 1 or 2 screws left out without that particular lug touching a ground point will have disastrous results
                  • buchman
                    • Aug 2015
                    • 283
                    • greece
                    Probably you were all right. found a few igbts shorted. this weekend I'll solder new ones hopefully it will help.
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      what are you using for the IGBTs ?? having a hard time finding good ones - EBAY ones are junk. can these be subbed ??? 30J124 & 30F124. thanks
                      • buchman
                        • Aug 2015
                        • 283
                        • greece
                        That is exactly what I am using. 30J124 as a substitute to the ones that been bad. I buy them from ebay or aliexpress.
                        • ajshoe
                          ajshoe
                          • Dec 2012
                          • 477
                          • usa
                          are u using 30J124 for both IGBTs ? that is u replaced 30f124 with 30J124 also ??
                          • buchman
                            • Aug 2015
                            • 283
                            • greece
                            30J124 is a replace for ir7ic....
                            • ajshoe
                              ajshoe
                              • Dec 2012
                              • 477
                              • usa
                              sa on some utubes where the 30j124 was being used to replace 30F124
                              • buchman
                                • Aug 2015
                                • 283
                                • greece
                                the only difference is that F is for voltages of up to 400V
                                and J is for up to 600V.
                                • buchman
                                  • Aug 2015
                                  • 283
                                  • greece
                                  My VZBIAS should be 125V and I am getting only 55V.
                                  What could be the reason?
                                  • ajshoe
                                    ajshoe
                                    • Dec 2012
                                    • 477
                                    • usa
                                    on my Ysus bd when IGBTs were shorted - also had (2) 2.2 ohm resistors shorted. check those. also check the 15V line on the Ysus board when the set is on from first startup. Mine would go to 18V then go down to 4.1V.
                                    • buchman
                                      • Aug 2015
                                      • 283
                                      • greece
                                      Mine isn't going to 18V it stays on 4.1V
                                      • ajshoe
                                        ajshoe
                                        • Dec 2012
                                        • 477
                                        • usa
                                        your problem is the Ysus - 15V, 15fl, 5fl, are all generated on the Ysus bd. either bad Ysus or bad panel
                                        • B0r1s
                                          Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                                          by B0r1s
                                          PSU - BN44-00878A
                                          Symptoms:
                                          The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                                          A weak clicking sound was coming from the transformer.
                                          Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                                          Progress:
                                          After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                                          01-17-2023, 04:58 PM
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
                                        • slimmy182
                                          [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                                          by slimmy182
                                          Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                                          I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                                          Looking on google I found this:...
                                          01-14-2023, 11:55 AM
                                        • beetle1303
                                          Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                          by beetle1303
                                          I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                          On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                          01-13-2025, 08:49 PM
                                        • Truncatedhose
                                          Help repair this relic? Philips 42PF7220A/37, pulsing buzz from YSUS
                                          by Truncatedhose
                                          Greetings all!
                                          Originally this set had the usual messed up video symptoms such as: horizontal lines, weak, grainy video, bottom and top of picture differ in intensity of problem. It also seemed to slow to turn on or show the messed up picture.
                                          Seemed like must be YScan/buffer board failure. Ordered buffer boards from my distributor which were supposed to be original/new and also from another distributor, I ordered the YSUS because I wanted to replace it for preventative maintenance. (also, the YSUS had a bulged cap, so there was even more reason to suspect it could...
                                          07-04-2018, 10:59 AM
