LG 42PT350R clicking problem fixed but still doesn't turn on
  • buchman
    • Aug 2015
    • 294
    • greece
    Re: LG 42PT350R clicking problem fixed but still doesn't turn on
    When I plugged everything together and turned the tv on, I heared a buzzing noise out of Z-SUS and Y-SUS boards.
    Once I heared that buzzing sound out of one of the IGBTs or transistors on the z-sus and then I found out that a couple of them were shorted.
    yesterday, before I plugged everything in, I checked for shorts and there weren't any shorts but I heared the buzzing sound.
    • PlasMatt
      LG 60PV450 Possible Bad YSUS Need help confirming Diagnosis
      by PlasMatt
      I have an LG plasma that after reading through a bunch of posts and doing some testing I believe has a bad YSUS board. The problem is that that doesn't make sense to me for some of the symptoms. The problem started yesterday. While watching a movie the TV just shut down like I pressed power. I have it hooked to a PC and use RS232 to turn it off and on so I thought maybe something had glitched there. I turned it back on and finished the movie with no problems. The same thing happened today so I checked logs to see if something in the control glitched and sent an off command but it didn't, After...
      09-20-2025, 06:50 PM
    • Sisko
      Onkyo-593 No power and now clicking sound
      by Sisko
      Hi all!!
      Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
      10-03-2025, 02:18 PM
    • B0r1s
      Samsung UE49KS7000SXXH - fast clicking sound in standby mode
      by B0r1s
      PSU - BN44-00878A
      Symptoms:
      The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
      A weak clicking sound was coming from the transformer.
      Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
      Progress:
      After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
      01-17-2023, 04:58 PM
    • legg
      LG 42PC3 buffer output doesn't follow YSUS
      by legg
      LG42PC3D -UD originally with green lamp but no display or audio.
      Owner says was working, then went 'pop'.
      All 5V caps bulging. replaced.
      All PSU output voltages within spec but -Vy is low on YSUS.
      One of three parallel fets between SUS_OUT and SUS_DN is zenering,
      eventually shorts DG. Replaced all 3 - -Vy now OK.
      Y scan buffer test point does not follow YSUS output below -50V
      Note: This unit seems to expect YSUS output to park at -Vy in between
      drive signal pattern periods. A replacement drive signal board confirms this....
      11-18-2021, 11:49 AM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
