Toshiba 40HL933G - LED Back Light voltages - should all chains be the same?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys, sorry to have a few threads all on the go at once right now. I have a spate of Toshiba TVs with back light problems - but this is a general LED question really.
    So I have on the bench now a Toshiba 40HL933G
    It has four chains of LEDs in parallel.
    The fault is the Power supply comes up OK (5V 12V 24V)
    PS_ON goes to 3.3V
    INV_ON_OFF goes to 3.3V
    BRIGHT_ADJ goes to 3.3V
    The back lights flash on very briefly and go out. BRIGHT_ADJ goes to 2.9V
    Pressing the standby button repeats the process
    When I test the LED chains with a back light tester they all illuminate but I see I have three chains with almost the same voltage 78.4V - 78.7V and the other chain is 84.9V
    I would have expected they would all be the same or at least much closer than that.
    Would such a large voltage difference on one chain cause the LED driver IC (in this case SSL110SN) to detect a fault condition on the LEDs and shut down hence the back lights flash briefly?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    Re: Toshiba 40HL933G - LED Back Light voltages - should all chains be the same?
    They are not connected directly in parallel, each string has its own PWM controlled MOSFET's (Q100 ~ 104) for maintaining constant current for each string. The Anode of all 4 string are tied to the same output of the Voltage boost converter circuit.
    What is the LCD panel model number?
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Its a Samsung LTA400HM22 Bud
      • vinceroger69
        • Mar 2012
        • 6714
        lcd panel specs link
        http://www.panelook.com/LTA400HM22_S...iew_15903.html
          https://www.badcaps.net/forum/attach...3&d=1518445891
          1) Turn the TV off, and then leave the black probe of the meter on the chassis.
          2) Put red probe on the test pad LED-1 of the LED driver board.
          3) Turn on the TV while watching the meter to see how high the Voltage goes up to and then wait 5 seconds to see how low it goes down to.
          4) Repeat 1, 2, and 3 step again but with test pads LED -2, LED-3, and LED -4.
          Report what you have on all four test points.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            Bit hard to measure as my Fluke DMM can't react fast enough to the peak voltage even with auto range switched off. I can read the low voltage quite accurately
            On the DMM it looks like
            LED1 1.49V -13.6V - 0V
            LED2 1.86V - 14.9V - 0V
            LED3 1.68V - 6.8V - 0V
            LED4 0.85V - 4.6V - 0V
            However on the analog scale on the Fluke I can see the peak voltage goes higher than those readings
            On my scope it looks like
            LEDS1, 2 & 3 1.8V - 30V - 0V with a square wave on the 30V which has a high % on duty cycle
            LED4 0.8V - 30V - 0V with a square wave on the 30V which has a low % on duty cycle
            Rich
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              Hi guys
              I'm still struggling to trace the problem on this one
              I tried disconnecting each LED chain in turn. With any of them disconnected I get a very brief flash on the backlights
              With all four connected I get back lights for maybe a second then they go out.
              So it would seem the SSL110SN LED driver can detect if a chain is open circuit which makes me wonder if it is kinda working and maybe detecting a false error condition?
              I know all the LED chains work OK on my back light tester albeit one has a larger voltage drop than the other three.
              Problem is I can't seem to find any meaningful data sheet on the SSL110SN with pin description.
              I guess I could just order a new SSL110SN and see what happens but i'm not convinced the driver chip is the fault here. Any suggestions?
              Rich
              • diif
                • Feb 2014
                • 6978
                • England
                The tester tests at low current and has indicated a string is not the same voltage as the others.
                That is what I'd check first.
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  OK I got it apart without breaking anything
                  The LEDs are on a single strip down one side, there are 14 LEDs per segment
                  Alol segments light up and interestingly they all read the same voltage on the backlight tester 78.5V for a short while but then the top segment went back to approx 85V
                  I also don't like the look how some LEDs look a bit 'burnt' and they don't all come on at the same brightness until the current ramps up.
                  As there are the same number of LEDs in each segment it would seem I do have a problem with the LED strip. Can anyone tell me the part number, there is no writing on the strip just a funny little square symbol
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    The part number is on the aluminium in photo 2.
                    https://www.aliexpress.com/item/orig...728500735.html
                    • Naruto-sama
                      • Oct 2023
                      • Italy
                      Hi, did you solve the problem by replacing the LEDs?
                        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                        by sam_sam_sam
                        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                        I am comparing them to a brand new one that I installed
                        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                        I going to let it run for several days before I remount back on the wall next to the...
                        09-05-2024, 06:48 PM
                        09-06-2024, 05:27 AM
                      • PNI E.
                        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                        by PNI E.
                        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                        02-20-2025, 08:36 AM
                        09-06-2024, 05:59 AM
