TCL LCD TV Orange Haze
  • StonedWookie
    • Feb 2018
    Hi All im having issues with my LCD TV this orange haze started to appear while the screen is black or when dark scenes in movies and gradually just got worse any way to repair this ?
    Re: TCL LCD TV Orange Haze
    Unfortunately I suspect the LCD panel has failed on your set, though it is a very unusual failure. It may be possible to fix the TV by replacing the T-con, or if iti is available, adjusting the VCOM voltage on the T-con or panel boards.
    • Watz
      • Sep 2014
      • 21
      • Kenya
      Re: TCL tv 49p3cfs Firmware
      TCl tv 49 curved displaying message starting smart system please wait....
      Whats the solution?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Please wait is displayed on your screen....and then what?....What error are you observing? A solution to what exactly?
        • will62
          • Dec 2016
          • 229
          • usa
          Possibly problems with a recent firmware update. You can try a factory reset.
          • serious_electron
            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
            by serious_electron
            Hello Everyone!
            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
            06-28-2025, 02:57 PM
          • mosfetratus
            macbook A2918, orange light off when shut off
            by mosfetratus
            When i fully shut off mac, orange light goes off and wont react to power button. I have difficult time resetting with combination "shift+control+option and power button", because it rarely works (reason unknown), when i manage to get orange light and then press power button macbook wont turn on and orange light goes off. When i hold combination with power button it turns on, and works fine if put it to sleep mode.
            Works with battery and charges, but when i shut off i get this problem.
            It had liquid spill. Board has no corrosion, keyboard is working, power button...
            05-31-2024, 03:34 AM
          • Weelcup
            XPS 9520 not powering up. Solid orange led
            by Weelcup
            Hi friends
            I have a dell XPS 9530 which had some liquid damage to the usb area. I replaced both the usbc iCs and not I can see 20v on the meter. But it does nothing and the 20v is not passing to charge the battery or turning on the board either.
            I suspected the PD controller (usbc controller) but it will need to be flashed if I decide to replace it. I thought that if the usbc controller needs flashing then at least the board should turn on on the battery. I charged the battery externally and attached it to the laptop. Now the 11.8v is actually passed to the board I can...
            10-20-2025, 04:22 PM
          • Catmouse
            HP EliteDesk 800 G4 - Orange LED behind Mainboard, not booting after BIOS Update
            by Catmouse
            I have 2 Elitedesk 800 G4 which have stopped working after a BIOS Update. It was doing the updates and instead of rebooting automatically it just stayed off and I was left with an orange LED being on behind the mainboard and no reaction at all when I hit the power button, it seems to be completely dead.
            Removing the battery, pressing and holding the yellow button on the MB didn't do anything either.
            Others have updated fine without any such issues.
            When googling I've found other people having the same issue with the orange LED being on and the PC also...
            10-29-2024, 04:27 AM
          • roxboy1984
            Lenovo ideapad 3 no power, orange light blinks once when charger inserted
            by roxboy1984
            Hi guys,
            I wonder if anyone has encountered this. I have a Lenovo ideapad 3 that shows no signs of life except when the charger is first inserted the orange charge light comes on for a brief second and then goes off. There is no other sign of life and no fans or lights come on.
            if I check the voltage going to the battery it spikes when I insert the charger and then hoes back down.
            i tried injecting 2V but nothing gets hot. Any ideas? Im still a noob.
            Today, 06:00 AM
