Samsung UE32EH5000 backlight issue fix
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Re: Samsung UE32EH5000 backlight issue fix
    Even as a beginner, I didn't crack a single screen and haven't had any unfortunate events so far. Mentally prepared is right, because the first time doing I was very careful and mindful throughout the whole procedure, then gaining more and more experience and fixing more and more of them, I gradually started doing it faster and faster, applying maybe a little bit more "force" with each one I did
    Panels ARE fragile indeed and the bigger the TV is, the harder the task, but unless you mess really bad, you should be able to get it out of there in one go and in one piece. They're not THAT paper-thin. Some tips if you haven't done this before, though some may vary depending on the TV:
    -once you get the bezel off, you'll want to release the buffer(s) board(s) so they hang freely off the edge. Most just pop off with a bit of encouraging, but check fro screws first (though I've never encountered screwed-on buffers on Sammies so far). You don't want the buffers to get left behind once you try pulling the panel away because they can strain the COF (chip-on-flex) cables (the ones running from the buffer to the panel).
    -remove the panel alongwith the supporting frame underneath it, instead of doing them separately. This way, when you place the panel down, it will be kept some distance away from the surface you're laying it on and stop dust and dirt from contacting the underside. The frame is held in place with clips on all sides. Be extra careful around the ones at the bottom because they're right underneath the COF cables and if you try using a tool like a screwdriver to release them, there's a possibility it will slip and poke a hole right through the COF! VERY bad and unlucky scenario.
    -lastly, the reflector sheets under the panel. This is where you no longer have to worry about doing surgical work, since the panel is off. Grab and remove all the reflectors at the same time and lay them flat in that order. Don't pull them out one by one - no need to go through all that trouble, plus you risk getting gunk stuck in between them, which often happens no matter how careful you think you are. They have a nasty habit of slipping and sliding around....not much advice I can give you here other than press them flat against each other to keep as much air from getting between as possible.
    Another thing about reusing LEDs: unless you have fairly good soldering skills and a good soldering iron/hot-air station, it's not going to be easy to pull LEDs off of a good strip without destroying them - I can tell you that much. They melt very easily, especially since they'd have to undergo TWO rounds of soldering: one to remove them from the good strip and the other to hopefully solder them back onto the faulty one. Of course, there's the infamous "stacking method" which involves chopping an entire working portion from a good strip and placing it on top of the dead LED with jumper wires, but I don't really favor that and don't regard it as particularly professional either.....go ahead and hate on me Good luck and let us know how it goes.
    Wattevah...
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Barely a week after I fixed the last one, another one came in with the same exact issue, though this one broke the rule of not showing visible signs, since the cap WAS bulging, making the task much easier.
      I can imagine all of these tellies came from the same generation and have approximately the same number of on hours, which might explain why everybody who bought them experienced failures at roughly the same time.....just a hunch.
      Wattevah...
      • fliperek
        • Poland
        I have the same problem in my BN44-00493B, capacitor defect
        • aaronwt6
          • Apr 2013
          • 855
          • US
          The 40" EH series have the same issue as well. Different power supply but exactly the same failure. I've fixed several. Some with bulged capacitors and others that weren't so obvious. I don't have the numbers handy but just a heads up to everyone.
            • 12081
            • U.S.
            I would go higher in voltage like 200 to 250 or so, same uf as previous cap just higher voltage.
              • 12081
              • U.S.
              #26
              I like those detailed posts Dannyyx, very helpful and informative.
              • brianbelfast
                • Jun 2010
                • 29
                • Northern Ireland
                #27
                Thanks Dannyx from me also. Fastest Samsung "No Backlight" repair ever. Much appreciated.
                • Janysek
                  • Dec 2019
                  • Česká republika
                  #28
                  Dannyx Good job thank you
                  • alfatv
                    • Sep 2020
                    • 353
                    It should be possible to check caps with a scope without removing them. You should see large spikes instead of relatively flat DC.
                    • CvendaCZ
                      • Apr 2022
                      • Czechia
                      #30
                      Iam glad Ive found this post, because it seems like this is my issue too. My capacitor is just slightly bulged, and I can measure 235-255V on backlight connector (160V when I disconenct the main board). The backlight in my case always blink on power up, and even tho I havent tested the LEDs, I can see that all of them blink. I really hope that the only problem is just this cap.
                      • electrocuted
                        • Aug 2023
                        • 39
                        • alban
                        #31
                        +1 you guys are time and effort savers! Replaced cm867 with a 120μF/200V which was available and works fine. No external leak or bulge and positive leg cut as in the first pictures.
                          09-07-2024, 05:50 AM
                        • vincentedel
                          Samsung SyncMaster 740n Phase Control Issue
                          by vincentedel
                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                          04-22-2025, 12:33 AM
                        • Manucsl
                          QE65Q800TATXXC Samsung TV Issue
                          by Manucsl
                          Hello.
                          My TV is a QE65Q800TATXXC Samsung TV.
                          Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
                          Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
                          Any ideas to check would be very appreciated 😊
                          After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
                          02-19-2025, 07:47 AM
                        • FourRunner
                          Display issue Samsung TV UA65JS9000W
                          by FourRunner
                          I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
                          10-03-2024, 07:05 PM
                          09-06-2024, 11:40 PM
