lc401e810e
  • meme123
    • Dec 2017
    • 5
    • palstinia
    lc401e810e
    Hello friends I have a lc40le810e Flash adds and restlessness and unresponsive device.
  • meme123
    • Dec 2017
    • 5
    • palstinia
    Re: lc401e810e
    I changed as someone said earlier, connect pin 9 bmkoamh link bedobs 11 resistance change 68 kg and it didn't work please help
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Re: lc401e810e
      OK. So when it's plugged into the ac, what does it do what does the TV do. Do you see any LED light at the front or is the light flashing??
      • ekozeko333
        [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
        by ekozeko333
        I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
        🔥 The Problem Started After Suspected ESD/PD Fault
        I experienced a power issue or ESD event through a USB-C charger
        After that, the NX20P5090 power switch was visibly burned and was replaced
        Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
        🧠 What I’ve Done So Far
        Flashed...
        06-21-2025, 02:48 AM
      • corrize
        Nikon D800 camera - flash don’t work and capacitor don’t charge
        by corrize
        Hello, I'm stuck in troubleshooting…
        The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
        In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
        When I press the flash button, it's detected by the system, flash icon appear on LDC display....
        10-01-2022, 10:02 AM
      • spmetroil
        Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
        by spmetroil
        I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
        The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
        I have a CH341A programmer and I already attempted the following steps:
        1. Identified the correct chip (W25Q128, 3.3V SPI flash).
        2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
        3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
        08-19-2025, 09:23 AM
      • abajor
        Canon VIXIA HF S10 A read data from inernal flash memory.
        by abajor
        Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
        Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
        The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
        I think my best shot is to figure out a way to read the internal flash memory outside...
        07-20-2024, 12:04 AM
      • Ihandyrepair
        4 red flash led 65X950G boot Sony and android logo but then black
        by Ihandyrepair
        HI guys
        I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
        here is the issue
        I have Sony and android logo. but then 4 led red flash lights front of the tv
        I have 3.3v ref. 12v reg then T con 12v when I press the power on button
        but then I get black screen and 4 red flash light at the front LED
        but I get 3 led flash on the LED driver board.
        I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
        so I tried...
        07-11-2024, 01:45 AM
