Vizio e320-a1 eeprom dump?
  • bdorset
    • Aug 2013
    • 30
    • St Vincent, Caribbean
    Please, can anyone help me with the eeprom dump U403 for VIZIO E320-A1 756TXDCB02K028 Main Board? Please keep in mind the mainboard number 756TXDCB02K028 since this set seems to use other mainboards. Thank you.
  • R_J
    • 9558
    Re: Vizio e320-a1 eeprom dump?
    Have you tried freezing the eeprom to see if the tv works, if it does you should be able to remove the flash, freeze it, read it and program a new chip.
    I have done it and have the bin for E371E & E390-A1
    • dskall
      • Oct 2016
      • 2905
      • usa
      If you succeed please share
      • pocketwatch62
        • 74
        • US
        R J
        you say you have the dump for a vizio E390-A1
        Model E390-A1
        mainboard----715G5560-M01-000-004K----TXCCB02K042
        PANEL---TPT390J1-HVN01 REV:000A
        If so could you post it or send it to me?
        • R_J
          • 9558
          I think this is the one that works, its been 4 years and I don't have any other information like board number etc.
          Whenever I try and upload a file larger than a couple megs I get this error
          Sorry I can't upload the file.
          A while back some people asked them to change something with the security on the site, ever since then I can't upload anythng larger than a couple meg file or picture
          Also my isp "upgraded" my service a while ago. That could also be the problem, faster speed but it don't fucking work any better!
          • pocketwatch62
            • 74
            • US
            Do you still have it? Could you post it PLEASE??
            • R_J
              • 9558
              Well it took me 20 tries but it finally uploaded, hope it works for you
              • pocketwatch62
                • 74
                • US
                Thanks R J
                It worked Plays like a new one!
                • R_J
                  • 9558
                  Good to here, This was taken from a tv that had an issue with the eeprom and I had to freeze the eeprom to get a good read, then reprogramed a new ic.
                  • AlexGsmMaster
                    Eizo CS2740 eeprom dump, search.
                    by AlexGsmMaster
                    Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                    07-26-2025, 03:24 PM
                  • edgarmg15
                    Damaged EEPROM on TV Vizio E320-A0
                    by edgarmg15
                    Hi everyone
                    I´m trying to repair a TV Vizio E320-A0 that I found in the street
                    The symptoms are it doesn't respond with remote or buttons, the LED indicator is always off and also there is no image on the TV.
                    The power supply board works fine (I probed the terminals with my multimeter) but in the main board the EEPROM doesn't works correctly because the voltage on the pins doesn't match with the parameters of the datasheet.
                    So, I´m going to replace the EEPROM with a new one, but the problem is that my programmer (CH341a)...
                    11-19-2022, 03:46 PM
                  • (0)_(0)
                    Looking for a HP Photosmart C4280 EEPROM dump
                    by (0)_(0)
                    Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                    The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                    02-17-2022, 09:09 PM
                  • my2k2
                    Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                    by my2k2
                    Good day to every one,
                    I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                    Does anybody have an eeprom dump file? I really appreciate any help.
                    Thanks in advance.
                    07-01-2024, 09:04 PM
                  • Whale linguini
                    p14s Gen 2 thunderbolt eeprom dump
                    by Whale linguini
                    P14s Gen 2
                    HT4B0/HP4B0/HT5B1/HT4B2
                    NM-D352 Rev 1.0
                    sn PF-35P15W
                    Requesting thunderbolt dump
                    also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                    09-03-2024, 01:56 PM
