identity tv part
  • nosugartonight
    • 107
    • united states
    identity tv part
    ON a power board. This part looks like a resistor but has no color bands. It is marked jw2 4.7 with ohms sign. They are 3 in a row. Checking in diode mode they read closed. What are they and what should they read.
  • nosugartonight
    • 107
    • united states
    Re: identity tv part
    Here is a pic
      They are 4.70 Ohms 2W connected in parallel, they are fine.
      You will get more help wit make and model and problem and good clear pictures of the whole top and bottom side of this power supply board.
      • nosugartonight
        • 107
        • united states
        Thanks. This is a vizio VO47LFHDTV30A Has no voltages on plug/cable going to main board. Checking voltages on hot side,using negative side of large cap for ground. Everything seems ok. It's when I get to the small transformer is when there is no voltages. I will try to add pics.
          We need good clear pictures so we can see what we are dealing with, must provide straight shot pictures of the top and bottom side of the board, the pictures must be clear enough to be able to trace out the cooper trace on the bottom side of the board.
          • nosugartonight
            • 107
            • united states
            Gotta. I'm trying to add pictures but after upload.stays on that screen and I click"close this window" goes back to message and everything I wrote is gone. Trying to figure it out ��
            • nosugartonight
              • 107
              • united states
              Think I have to upload one at a time
              • nosugartonight
                • 107
                • united states
                Top left
                • nosugartonight
                  • 107
                  • united states
                  Bottom left
                  • nosugartonight
                    • 107
                    • united states
                    Top right
                    • nosugartonight
                      • 107
                      • united states
                      Bottom right. Hope they are ok
                      • nosugartonight
                        • 107
                        • united states
                        Board number 0500-0407-0680
                        • nosugartonight
                          • 107
                          • united states
                          Ok . Can you please tell me if the pictures are good enough
                            https://www.badcaps.net/forum/attach...5&d=1517185124
                            So you are 100% sure that you do not have any DC Voltage on the 5VSB pins at all?
                            • R_J
                              • 9611
                              Check if R901 or R902 is open, and if Q901 is shorted
                              • nosugartonight
                                • 107
                                • united states
                                Ok here what I have discovered. Before I removed the power board to take pics. There was no voltages on any pins . Everything on hot side shows voltages. I believe there all right. No voltages on cold side. But when I went to put the board back. I only used a couple of screw's. I rechecked the pins. To my surprise there are voltages on the pins. When I put the bottom right screw in. Lost all voltages on pins. Tracing from the 5v pins . Everything shows grounded. All the way up to pc702 which looks like a IC but only has 4 legs. . I will post a pic. I hope you understand what I'm saying
                                • nosugartonight
                                  • 107
                                  • united states
                                  The leg in pointing to is grounded
                                  • nosugartonight
                                    • 107
                                    • united states
                                    Should it be grounded. This leg is the only one from all 3 ic's
                                    • R_J
                                      • 9611
                                      It might be, how about turning the board over and trace the line to see if it goes to ground, it's hard to tell looking at pictures only.
                                      "Tracing from the 5v pins . Everything shows grounded"Are you saying that you have a short on CN201 between SGND and 5VSB?
                                      • nosugartonight
                                        • 107
                                        • united states
                                        I can do that,ASP. Thanks for your info
                                        • edugimeno
                                          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                                          by edugimeno
                                          Hi There!
                                          I'm trying to help my friend who owns a restaurant be just bought.
                                          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                                          It's stuck using, I guess, the 2 sided tape that comes with the strip
                                          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                                          09-05-2024, 09:34 AM
                                        • G-Sting
                                          iPad Pro A1876 SHORT Part Identify Help Needed
                                          by G-Sting
                                          So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
                                          So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
                                          i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
                                          SO My main concern is what part should i order what should i search the name for ?
                                          on Ipad...
                                          05-15-2025, 09:30 AM
                                        • narf
                                          Epson EB-U42 projector / Caps with 0.7 ohms ?!
                                          by narf
                                          hi all,
                                          first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
                                          i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
                                          what i've found so far:
                                          - the PSU does its job and supplies 12V to the mainboard via the connector.
                                          - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
                                          - not far away, there's the first cap with a resistance of 0.7 ohms....
                                          07-02-2024, 03:53 PM
                                        • Yanleb
                                          Panasonic part number in service manuals
                                          by Yanleb
                                          In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
                                          This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
                                          For an example, look at the attached PDF.
                                          Do you have a way to cross reference the Panasonic part number with the actual part number?
                                          Thanks....
                                          07-03-2023, 08:16 PM
                                        • FreakyMex
                                          Trouble to identify part (Lunii screen) for replacement
                                          by FreakyMex
                                          Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
                                          I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
                                          02-17-2025, 01:16 AM
