Hi guys,
My Samsung Plasma TV PN51D6900 went to the power cycle mode. Not a rare occasion. It is 7 years old and the picture quality was still awesome, so I decided to try and repair it if I can. I did some research online and most problems like that were described by being caused by bad capacitors.
I need help identifying what is the problem with my TV, so first here are some numbers:
TV model number : PN51D6900
Power supply board number: BN44-00446A (PSPF371501A)
And some pictures:
Symptoms:
Upon plugging on the TV powers on. In about 17-18 seconds it turns off. In another 2-3 seconds it turns off. And the cycle repeats. The longest I left it to repeat was for about 15 minutes.
While the TV is powering on the red stand by LED on the front blinks 5 times about 1 blink per second.
The green LED on the small board below the power board blinks at 1 blink per second for the whole time the TV is on.
Steps I have taken so far:
1. Looked closely to see if I can spot any capacitors that are leaking, bulged or deformed as described in this post
2. Red the troubleshooting in the service manual, but could not find a solution.
3. Measured the VS-ADJ (top right corner near the 2 caps), VA-ADJ (middle right side) and all pins on connector CN801 (bottom right corner) that supply the main board. All values are as stated in the output table below the 4 big capacitors in the bottom left side of the board or near the CN801 connector.
4. Measured all large electrolyte capacitors with a multi-meter. All values measured match the value printed on the capacitor. Some capacitors are connected in parallel and then the measured value is very close to the sum of the values of the individual capacitors (the four long caps between the heat sinks on the power board, the 2 long caps above the other heat sink on the power board, the group in the top side of the board in the left hand side).
I noticed some deviations of the measured value and the expected value tor the 2 groups of four green capacitor on the top side of the right hand side board and in the bottom part of the left hand side board. Both groups are made of 4 caps 150 micro F each, but when measured my multi-meter reads 1500 micro F for the whole group. I thought that my be the problem until the second group made by the same caps measured the exact same value.
The second deviation was the group of two brown caps 220 micro F each located directly bellow the group of four green caps on the right hand side board. their measured value was 680 micro F.
All measurements were made without removing the capacitors from the bords.
5. Disconnected connector CN804 in the top right side of the board.
The TV still goes through a power cycle, but a bit different at this time:
TV powers on for about 25-26 seconds and off for about 2-3 second and repeats.
- the red stand by LED on the front still give 5 blinks at about 1 blink per second
- the green LED gives one short blink, then stays on for 5 seconds, off for 2 seconds and repeats until the TV turns off.
6. Disconnected connector CN802 in the bottom right corner of the board (just below the heat sink) that supplies power to the small logic board.
The TV goes through another power cycle - on for about 45 seconds, off for 2-3 seconds and repeat.
- as the logic board is disconnected the green LED is off.
7. Disconnected connector CN801 (bottom right corner) that supply the main board - TV is off and will not power on.
I appreciate any advise that can help me diagnose further and repair this TV.
And some pictures:
Symptoms:
