Sharp TV Bad tab drivers?
+ More Options
Posts
  • jjanssen7
    • Nov 2012
    • 252
    Re: Sharp TV Bad tab drivers?
    I have done 40-50 of each (cut off tape & tab removal) and in my experience it's an either-or situation. Remove tabs or if there are none, do the tape trick.
    • budwich
      • Jul 2015
      • 3097
      sheesh!! I wonder if there are any of these sets with good innards... :-) I think the question still is, if one has side tabs, will the "cutoff tape" method work?
      • eaglei22
        • 12
        • US
        Hey guys, thanks for the replies. I had gotten a warranty replacement on the tv so i just put this one in the basement once I got the knew one. Because there is a small risk to cutting the tabs and the lines were very skinny (at the time) I just left it.
        I was going to start using it in the basement while exercising.. then I got rhabdo, spent time in the hospital and stopped exercising for a long while as mentioned.
        Anyway.. so you're thinking the driver tab exacerbated the power flux and possibly shorted out the power board?
        • jjanssen7
          • Nov 2012
          • 252
          In my experience, it the tv came with tabs then the only fix is to remove them. If it is the type that does not have tabs then the tape cut off method is the only choice. Ive never been able to get the tape methid to work on a tv with tabs.
          • nomoresonys
            • 12094
            • U.S.
            Ok, thanks Jjanssen7. If I had the space I would get some to operate on to save from landfill and give to poor friends and deserving relatives.
            • budwich
              • Jul 2015
              • 3097
              noooo. it is unlikely that there is anything wrong with the power board... the error code is an indication that the system doesn't like some "level" associated with powering but doesn't actually mean that the power board is broken. This can only be confirm by checking the voltages though.
              • nomoresonys
                • 12094
                • U.S.
                #27
                Yep, the side with the line is the side the tabs need removed from, many detailed threads on here for determining which side and tab removal procedure, remember just remove side tabs and only ONE side, the bad side.
                • wagivem657
                  Sharp LC-55LE643U, bad gate drivers?
                  by wagivem657
                  Just received a busted Sharp 55" Aquos (LC-55LE643U) from a coworker. He tried swapping all three boards (power, main, TCON) to fix the problem, but it had the same issue. He was kind enough to give me the TV and both sets of boards for free, so I can try to get it working for myself.
                  Unfortunately, I think I may have made the problem (much) worse, but I'm interested to see if the original problem was fixable at all regardless...
                  Pictures show the issues:
                  1. shows what happens when you first turn the TV on. Well, kinda, the white column wasn't there at
                  01-29-2021, 08:13 PM
                • japlytic
                  DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                  by japlytic
                  In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                  Tried (only with keyboard/mouse connected):
                  • BIOS + database update
                  • Using latest Windows 11 image built with official image creation tool
                  • Previous setup version for Windows 11 installer
                  • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                  • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                  • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                  06-19-2025, 04:59 PM
                • pavithra
                  LC6685 based LED drivers
                  by pavithra
                  I have 50 Chinese constant current isolated LED drivers based on LC6685 IC. 35 drivers are working fine, but there is a slight flickering in the rest of the drivers.
                  I have checked the output with oscilloscope and found that there is a slight random voltage fluctuation.
                  Is it possible to get the datasheet of LC6685 IC?
                  Also highly appreciate if you could let me know what could go wrong....
                  04-16-2024, 02:46 AM
                • advant
                  by advant
                  02-03-2020, 12:25 AM
                • kuba2102
                  Alienware m15 R4 CPU or CPU drivers issue
                  by kuba2102
                  Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
                  01-04-2023, 09:05 AM
