LG 50LN5750 bad back light and odd question.
  • freakaftr8
    • Oct 2012
    • 3743
    I got this TV in for repair last night. Typical shorted LED strip. Got the back lights up and running and noticed I have no control over backlight control on the menus. It stays just as bright no matter what I do. Also APS power save mode does not seem to do anything. This obviously is either a firmware issue or the power supply simply does not control PWM dimming.
    So I am going to do it manually by stepping up the resistor value. My question is has anyone run into an issue where you cannot control backlight dimming on one of these LG's yet?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 50LN5750 bad back light and odd question.
    LGs normally have a 'backlight' control in the User menu. If this does not control the backlights then yes stepping up the resistor value is the only option available. I have a R-C Substitution box that I use for that purpose. It will work out. Go brave.
    • freakaftr8
      • Oct 2012
      • 3743
      I'm just surprised the backlight control and the power save APS mode doesn't work..
      • neilc6
        • Nov 2015
        • 1550
        User manual says there is backlight control http://www.lg.com/ca_en/support/supp...ct/lg-50LN5750
        • britishbloke
          • Oct 2011
          • 5
          Could the TV be in store demo mode?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            'I have no control over backlight control on the menus'.
            Do you mean the backlight control is greyed out or is there no adjuster control showing?
            Could really be in DEMO Mode as britishbloke suggests. However, I doubt it. Could you get to do a factory reset?
            • freakaftr8
              • Oct 2012
              • 3743
              No the backlight control is there is just not doing anything. However problem solved. I guess that you have to have it connected to an input in order to see the effects of the backlight control.
              Shady.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                You got me there, Pardner......Glad you figured out the problem......Problem was the User...hee...hee...hee
                • freakaftr8
                  • Oct 2012
                  • 3743
                  Yes stupid me lol however on the fault of LG's part, Backlights at full luminance no matter where you have it adjusted on the menus When there is no signal fed to the television
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    I think you may have to adjust the backlight separately for each input, as the setting for HDMI is not the same setting for Video or TV, etc.
                      +1. I have to do that on my LG and SAMSUNG.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Right, Im aware of backlight adjustments in each input including the common adjustment to add values to all ports.
                        However with the backlights adjusted down to 60% which is about as far as I'm willing to take these LG's, If I disconnect the H DMI cable or disconnect a component cable or whatever input I'm on, The backlights will go back to full luminance Until the source is connected again.
                          Hmm, I will try that with my LG tonight.
                          42" LG in my bed room is at 35, 47" for the living room is at 50 and both are still pretty bright to me.
                          BTW, you said it goes to full when input is removed so the Backlights indicator bar goes to 100?
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            No indicator bar stays at where I have it set, just luminance maxes out
                              But luminance is not the same as the Backlights.
                              • freakaftr8
                                • Oct 2012
                                • 3743
                                Ok I meant backlight level.
                                • arenat
                                  • Nov 2015
                                  • 22
                                  • Argentina
                                  I´ve had that issue several times with LGs . No control no matter what , some work after factory reset , some don´t . It´s a software issue . Two identical 32LB560B , one work fine , control with no signal at all , the other like the OP´s.
                                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                    I am comparing them to a brand new one that I installed
                                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                    I going to let it run for several days before I remount back on the wall next to the...
                                    09-05-2024, 06:48 PM
                                  • PNI E.
                                    tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
                                    by PNI E.
                                    hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
                                    02-20-2025, 08:36 AM
                                  • koby058
                                    vostro comes up with back light but no picture
                                    by koby058
                                    Hi people!!
                                    The owner said it showed bad picture once in a while (attached)
                                    I see that there is back light but no picture.
                                    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                                    Also attached schematic and BDV
                                    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                                    07-13-2025, 01:03 PM
                                  • jdawg99
                                    LG 47LA620V Same LED Failing Back Light Issues
                                    by jdawg99
                                    Hi All,
                                    I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
                                    04-23-2023, 01:04 PM
                                  • nouriassafi
                                    PWM Dimming Control Signal low voltage drop LA-E841P
                                    by nouriassafi
                                    JEDP pinout LA-E841P:
                                    4,5 MLO (Main-Lane)
                                    7,8 AUX (Auxiliary Channel)
                                    9,10 VCCS (Power Supply +3.3V)
                                    11 HPD (Hot Plug Detect)
                                    15 LED_EN (BL_ENABLE Signal of LED Converter)
                                    16 LED_PWM (PWM Dimming Control Signal)
                                    19,20 LCD_VCCS (BL Power)
                                    Have an issue with pin 16 (PWM Dimming Control Signal): low voltage drop!
                                    Any help would be much appreciated!
                                    06-19-2022, 08:32 PM
