UN32EH4003F Blue Screen?
  • MPDano
    • 6
    Hello all,
    First post here. I got a UN32EH4003F and verified backlights are working. The only other board that is replaceable is the mainboard and replaced it and no change. I am just getting a blue screen and cannot access the menu. It does play the boot up sound when turning on.
    There is another board but it's connected to the screen without a way to disconnect it.
    I tried the reset using the remote without any luck.
    Any thoughts?
    Much Thanks,
    Leo
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: UN32EH4003F Blue Screen?
    Is the blue screen a bright blue or dim from backlights?
    • MPDano
      • 6
      All backlights are on. Just a blue picture.
        Can we see the screen shot of the screen so we can see exactly what you are seeing on the screen?
        • freakaftr8
          • Oct 2012
          • 3743
          Does the picture change if you disconnect the ribbon cable to the panel?
          • MPDano
            • 6
            Thanks all. I cracked the lcd while trying to put the plastic surround back. Hard to capture the blue as it's light. Unplugging the ribbon cable to the unservicable board to lcd has no affect on change.
            Going to part it out as I broke the screen. I have a feeling it's that board (driver?) connected to the screen which is unconnectable.
            • dskall
              • Oct 2016
              • 2905
              • usa
              You have backlights only. Probably bad t-con/main board. Power supply probably only good part.
              • MPDano
                • 6
                mainboard was replaced. where is the t-con? It's not like my other samsung which is replaceable. see my uploaded pics.
                  This LCD panel uses integrated T-CON on this one.
                  • MPDano
                    • 6
                    Yeah, kinda sucks the way this model was set up. Oh well. I really do appreciate all the assistance this board has given.
                    Leo
                      It is also bad panel to have because the tab bonding boards are on the bottom edge of the screen so as the user sprays glass cleaner on the screen instead of spraying on the cleaning cloth, the liquid drips on to the tab boding board and cause corrosion ans shorts circuit.
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • jean luc ferre
                        acer aspire v5 571p touching screen cracked led blue of power indicator blinks 1s lighted 3s off.
                        by jean luc ferre
                        on this laptop acer aspire v571p the led of the power indicator blinks blue for periods of 1s lighted and 3s off after switch on and this indefinitely.
                        i tried the hard reset, cmos reset, changing the ram without results.
                        in order to reach the cmos battery i disassembled the laptop and did several mesures with my multimeter.
                        The 19v, 5v, 3v are well established after the chip 5v-3v. the following signals : 3d3v_aux_kbc (which supplies the sio chip) and 3d3_s5 are well established also.
                        but the signals: 3dv3_s0, pw_slp_s3# and pw_slp_s4 oscillate at the same...
                        11-22-2025, 03:54 PM
                      • Chrissygizmo
                        Panasonic TX-48CX350B backlights but white screen , blank screen
                        by Chrissygizmo
                        Hi all, I’ve got a problem I hope someone can help me fixi.
                        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                        01-11-2025, 03:18 PM
                      • dicky96
                        HP Elitebook Screen blank - backlights but no image
                        by dicky96
                        Hi guys
                        I'm trying to fix this laptop screen
                        Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
                        OK so I have the original screen which works but has lines across the bottom quarter of the screen
                        I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
                        04-28-2021, 07:30 AM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
