LG lines
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    LG lines
    Hi what can anyone tell me about the screen,panel or is it a tcon issue,i have cleaned connecting ribbon but no change.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: LG lines
    Looks like tab bond on panel
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Re: LG lines
      Death by windex? Look at ribbons coming out of panel at bottom,look closely at them where the lines are. Corrosion on them?
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        Re: LG lines
        windex ? from the panel to the tcon ok,even cleaned ! could it be the tab bond,where do i buy replacement bonding ? not sure the panel even comes apart.
        • dskall
          • Oct 2016
          • 2905
          • usa
          Re: LG lines
          Basically not repairable
          • LEEDASH
            • Dec 2012
            • 481
            • Bedfordshire
            Re: LG lines
            you answer is contradicting ? first off its ribbon bond then not repairable.
            • johnboy1313
              • Nov 2012
              • 1959
              Re: LG lines
              Ribbon bonds aren't repairable without multi-thousand dollar machines. No contradiction at all.
                Re: LG lines
                That's not a contradiction. Not all ribbon bond failures are repairable. Generally only those between the ribbon and PCB are. Those between the ribbon and panel are essentially not repairable unless you have an LCD panel rebond jig...not going to happen.
                too long didn't read - panel's fucked.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Re: LG lines
                  Didn't see the photo with the lines down. Post deleted.
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    Re: LG lines
                    say no more.
                      Re: LG lines
                      Could still be caused by Windex!
                      • martino
                        Not so "senior"
                        • Aug 2013
                        • 997
                        • canada
                        Re: LG lines
                        Death by windex(household product people use to clean glass surfaces),might have a different name in your knack of the woods,is an expression used by many of us here .
                        What it means is that when people clean their tv screen with a product like windex or any other liquid type cleaner,that in the process of doing that fluid can run down the panel and hang like drops off the bottom of the panel,inside the tv,right where the ribbon cables come out of the panel. Over time this can cause damage to those ribbons.
                        Hope that gives you a better idea of what I was trying to say.
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Re: LG lines
                          Liquid can run down the screen and cables and sit in the connectors and corrode the contacts.
                          I have been lucky and been able to repair a couple in the past by soldering in fine wires direct to the soldered pins on the ffc sockets.
                          I've also see it destroy tab bonds.
                          Only way know for sure is to strip the panel down.
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • zesko
                            xps 9520 ribbon cable
                            by zesko
                            I have a XPS 9520 with broken daughter board and missing ribbon cable. I can fix the board by replacing the connector, but I can't find the correct ribbon.
                            There is 2 models, idk which one is needed on my laptop.
                            0xkvng
                            00vpr2
                            Daughter board is LS H822P. When I check for a palmrest, the board attached to have a 0xkvng ribbon. But when I check for LS h822p, it's 00vpr2 ribbon...
                            Someone can help me with that please ? Idk the difference between these 2 ribbon but they definitely doesn't look the same..
                            thanks...
                            10-23-2025, 05:03 PM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • mrsith
                            Samsung UE70TU7100 - flickering horizontal lines
                            by mrsith
                            Hello again good souls.
                            Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
                            I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
                            02-13-2023, 05:36 AM
                          • Rubenlily
                            Samsung QE50Q67TAU - horizontal lines
                            by Rubenlily
                            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                            I'm no expert but I've done the tape...
                            08-16-2023, 01:12 PM
