whole new repair / learning world... plasma! Yikes!
  • Moreno83
    replied
    Re: whole new repair / learning world... plasma! Yikes!
    Good luck!
    I usually cut the legs and apply solder to the back of the IGBT and i use a 60w solder iron , works perfectly.
  • budwich
    replied
    OK... I will give it at try... thanks.
  • tvtimmy
    replied
    40 watt. Works great for me. You can lift the legs, like in the vid, and test parts. The smaller fgd4536 are easier to resolder to the board and run cooler.
  • budwich
    replied
    thanks tvtimmy.... that looks doable for my equipment and "lead hands". One question, what wattage of soldering iron are you using?
  • budwich
    replied
    OK... I did a check of the "pin spacing" on the fdg4536 versus the board solder pads and it appears that they can indeed sit appropriately on the board. It would appear that if one uses the fdg4536 that if they were to "blow" (physically explode) since they are so much smaller, that perhaps there might be less potential board damage.... maybe... :-)
    Of course, it would be even better if nothing bad happened... :-)
  • tvtimmy
    replied
    Dont use the big heat gun. Watch this video, on youtube.its how I remove them.
    10:28
    TNPA5335 Repair Kit
    TV Repair Kits
  • budwich
    replied
    OK.... The "parts boat" came in so I started looking at this again. I ordered a couple of different sourced (china) 30f131's. I also order the two diode types (rfn10 ns3s and rf1501 ns3s). They all came in a form of "capsule packaging" similar to the picture that I posted, they look new. I haven't did any "bench check measuring" to compare values at a "thumb level". The one question that I have is, it was suggested that FGD4536 could be a "safe" substitute for the 30f131 (maybe less "fake"). Anyways, my question is: the FDG4536 "form factor" is less than half that of the 30f131.... is this correct? Its hard to believe that these things handle 50AMPs. I am not even sure that the pins will align with the board solder pads / tracks.
    I am proceeding slowly as I decided to give a hot air desoldering station a go and am now waiting on that "boat".... but in the meantime. I might give my "big heat gun" a shot to see if its doable as I am getting somewhat impatient to see if this "recycle bin tv" can be operational.
  • budwich
    replied
    I ordered parts from "off shore" ... :-) I haven't gotten all of them yet plus I am not able to continue with the repair at this point due to other things happening. I hope to get to this some times next month and hope to post a success. I am still considering some sort of hot air solder station (cheap one) to help with this and any future work that might require "reflowing" and such. I will give the "hot air gun" a try as I have one from guitar building work (bending sides)... just not sure it can be "aimed" good enough.
  • nwcs
    replied
    budwich, Did the repair kit from shop jimmy fix the issue?
  • budwich
    replied
    thanks again, will look at those IC's in question. They don't appear in the shopjimmy kit / help for the sc card (or mentioned) so hopefully although maybe a common failure, they are OK.... this tv isn't going toward anyone so I can "redo" if necessary. If they are bad, will they take out other components "again". Will they generate any sort of "flash code" that points at them if / once the set is powered up after the other repairs.
    attached is a picture of the igbts... hard to tell anything... I will see I guess.
    Its going to be awhile since the boat is always slow getting.... which is good since this is going on the back burner for now.
  • Moreno83
    replied
    I doubt you get the original ones. We will see what happens.
    http://4.bp.blogspot.com/-z7bycQ_nfH...600/pana05.jpg
    BD8693FVM. That's the control IC.
    3Y (SMD Code) is a CPH5524-TL-E
    Replace RJP30H2A and 30F131 for FGD4536TM
    There is a long thread about the fake 30F131 on this forum.
  • budwich
    replied
    oh oh.... that's not fun. i need to look closer..... hmmmm.
    this is what I order...
    "NEW TOSHIBA GT30F131 30F131 TO-263 MOSFET" from china... doesn't appear to align with your "code warning"... I figured the "toshiba" would hopefully be a good sign.
  • Moreno83
    replied
    You need to watch out what components you buy. Dont buy the 30F131/RJP30H2A from china unless you want some fireworks.
    FGD4536TM , there are some fakes on the market also so i hope you get the good ones.
    On this particular board the DG301/302 fail also. It measures good on the outside but interal is still damaged.
    Also the 2 small ic's on the board are usually dead. IC501 out of my head......
  • budwich
    replied
    i will probably add some star washers that will hopefully help with both lock down and contact to the track.
  • freakaftr8
    replied
    Shop Jimmy screws are more tailor to trying to keep the board locked down. Floating grounds are all about these boards. This is a number one failure of sustain boards in Panasonic's.
    When I repair a sustained board I usually take out all the screws wire brush and. If I'm at work where I own a machine shop I put them on a screwdriver in wire wheel the hell out of them to clean them all up. A few times I've used blue loctite on the screw threads. I'm not sure if this helps or not, However I've noticed on a few repairs that the screw holes feel definitely loose. On a few of those I went down to the hardware store in but coarse threaded screws with loch washers. Any of the scenarios I haven't heard of a problem arising as of yet over the last 4 years
  • budwich
    replied
    not sure what the difference is but the screws have an "integrated washer header"... meaning the screw head has its main body and then there is a wider metal rim. It is certainly not the type that the shopjimmy kit has which has a washer and spring associated with the screw.
  • vinceroger69
    replied
    what type of screws hold this board down the older type or the newer upgraded ones.
  • budwich
    replied
    looking at the surface closer, it appears to be somewhat like "aluminum oxide"... kind like the thing that happens with aluminum electrical wiring when it mates with the wrong type of switches. I have likely sanded them clean to ensure better contact.
    It doesn't appear that I can get the components locally so its "off to china".... slow boat here I come.... that's ok as I probably have to "shelf" the project for a while.
    Thanks for all the help on this. I hope it is ultimately successful and will post the outcome when and if I get there.
  • budwich
    replied
    took the board off. pictures show some of the contacts on the bottom side have issues. Top side looks OK. My question is shouldn't most of the "contact surface" be from the screw thread contact area? The "stand off" mount "dimple" is a coated surface which meets at those "dark areas" so I wouldn't expect it to be a good point of contact... should be this be sanded to a good metal look on that mount surface?
  • budwich
    replied
    thanks... I am hoping I can find something locally but chances are slim as we are in the "back waters of technology"... canada you say... :-)
  • Firentiosi
    1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
    by Firentiosi
    Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
    The issues are as follows: the...
    11-27-2024, 12:33 AM
  • ArMaaN376
    Samsung PS51E550 Plasma TV
    by ArMaaN376
    I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
    Opened TV cover & observed foll
    a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
    b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
    c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
    How to confirm Y -Buffer board...
    06-19-2024, 04:05 AM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
  • KYBOSH
    Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
    by KYBOSH
    Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
    No picture but you hear the TV static (white noise) playing loud and clear.
    The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
    But it seems they didn't get too far and just left it.
    When I first took a look I was amazed at how pristine the inside looked.
    Its as if the TV had been in a time capsule.
    Caps looked like they were just pulled off the self.
    Copper coils had no sign of corrosion on...
    02-01-2023, 11:10 PM
  • porfyriadhs
    Samsung Plasma PS51D6900DS Bootloop
    by porfyriadhs
    Hello . I have a problem with a samsung plasma tv stuck in bootloop . The TV is Samsung PS51D6900DS plasma smart tv .Need help if anyone have any suggestions
    Thanks a lot !!
    10-19-2023, 11:31 AM
