Vizio e701-a3
  • robert phelps
    • Dec 2016
    • 94
    • usa
    Vizio e701-a3
    I this set is got cheap, had a bad leds strip, replaced it, put set together and on the right and left sides of the screen, top to bottom looks like mountain ranges, highs and lows areas where there is no picture. Also 3 guarters of the way up on the right side is a line that goes from right to left 3 quarter across the screen. Can the t- contacts cause this? This set has 2 boards on the right and 2 boards on the left of the panel, and 4 across the bottom of set with jumper ribbon cables
  • robert phelps
    • Dec 2016
    • 94
    • usa
    Re: Vizio e701-a3
    Also set has great picture other then the edges
    • dskall
      • Oct 2016
      • 2905
      • usa
      Re: Vizio e701-a3
      Need some pictures of problem
      • freakaftr8
        • Oct 2012
        • 3743
        Re: Vizio e701-a3
        Possibility that you didn't install the white diffuser sheet properly
        • robert phelps
          • Dec 2016
          • 94
          • usa
          Re: Vizio e701-a3
          Here are pics with out bezel on tv
          • dskall
            • Oct 2016
            • 2905
            • usa
            Re: Vizio e701-a3
            Do you know if you had this problem before you worked on it?
            • robert phelps
              • Dec 2016
              • 94
              • usa
              Re: Vizio e701-a3
              Don't know, guy I got it from said picture wasn't working, he knew about the flashlight test and could see the image, until I replaced the led strip was when I first saw the screen all lite up
              • robert phelps
                • Dec 2016
                • 94
                • usa
                Re: Vizio e701-a3
                Shopjimmy video says these sets have a 70% panel failure rate, I hope not
                • budwich
                  • Jul 2015
                  • 3097
                  Re: Vizio e701-a3
                  if it is still not totally "buttoned up", you can try disconnecting one of the tcon to panel cables and see what the result is on the picture. It should go all white on that side... hopefully.
                  My guess is you put it back together wrong such that there is pressure on the lcds... much like when you push on an lcd with your finger, it goes dark.... maybe... although that looks black which I do believe is kind of like a "grounding" issue.
                  • robert phelps
                    • Dec 2016
                    • 94
                    • usa
                    Re: Vizio e701-a3
                    Ok will try that
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Re: Vizio e701-a3
                      The panel should be loose and not under pressure. Did you put panel directly on the diffuser sheets?
                      • robert phelps
                        • Dec 2016
                        • 94
                        • usa
                        Re: Vizio e701-a3
                        Well unhooked t-con to panel ribbon on one side, was all white on that side, could still see edges like described, unhooked both sides from t-con and just backlights, can still see edges and line at top of screen. Anyone need parts for a 70 inch vizio
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          Re: Vizio e701-a3
                          When you removed and reinstalled the screen did you make sure that you didn't cause any damage to the LCD panel? The look I'm seeing looks like LCD pressure bleed.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Re: Vizio e701-a3
                            This is a symptom of what happens to an LCD panel when it gets hit too hard or pressed to the point where it doesn't crack but it stresses the panel and puts pressure on the dialectic layers. Essentially it's bleeding internally
                            • Pinky Deepak
                              Vizio M60-C3 Left Edge problem
                              by Pinky Deepak
                              I have a M60-C3 where the left edge has started showing issues as seen in the picture attached. Along with this, I also noticed some darkening on the left half of the screen which went away after I left the TV unplugged. i initially thought it was the led backlight that was wearing out but looks like something to do w the TCONN board. I searched this forum but couldn't find anyone else seeing this issue. most of them were LH/RH completely gone. any insights or guidance is appreciated.
                              Here's a video of both the issues: https://youtu.be/hMqc760nB3o
                              09-27-2024, 05:11 PM
                            • SS454
                              vizio e650i-a2 backlight flashes then turns off
                              by SS454
                              vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                              panel: au optronics T650HVN05.4
                              72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                              link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                              Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                              https://www.shopjimmy.com/vizio-56-0...-power-supply/
                              Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                              08-20-2020, 03:57 PM
                            • frannyjunk
                              Vizio M60-C3 left side of screen + a couple other areas dim
                              by frannyjunk
                              My Vizio M60-C3 was dead. No power, no lights. Just nothing. So I took the back cover off and noticed 4 bulging caps on the power supply board, so I replaced them (green low esr capacitors in the picture). The tv now works! But there are some areas that look dim (see picture). In particular, the left side has a dim band. I know that the led strips run horizontal, yet this band is vertical. Could it be that the led driver board is bad? Could the blown caps have taken out the led driver board? Or is this just a coincidence that every left side led on each strip just went out?...
                              11-10-2021, 08:09 PM
                            • karatzdi
                              Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
                              by karatzdi
                              I know some might say... just buy another one. Sell it as parts..!
                              So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
                              Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
                              Spent some time downloading the Service...
                              06-11-2024, 08:38 AM
