Lg 42PJ350 no Picture
    Re: Lg 42PJ350 no Picture
    15V and 15VF are different supplies
    15VF is referenced to the Y-sustain output the same ground used by -Vy and Vsc voltages. It is used by gate drivers and to generate 5VF for buffer boards.
    • ajshoe
      ajshoe
      • Dec 2012
      • 477
      • usa
      #42
      just to re-cap. LG 42pj350 plasma that turns on - stays on, logic bd has erratic led flashes, all SMPS voltages are good, Vs, Va all good on Ysus & Zsus bds, 15V off of Ysus is @ 18V on turn on then goes to 4.1V, can hear plasma display come on for 2 seconds, NO DISPLAY. I have replaced Buffer bd, Ysus bd (twice), Zsus bd, logic bd, SMPS, absolutely no change in symptoms with any of those bds.
      something is telling Ysus bd to turn off 15V. Is this bad panel ????
        I doubt anything is telling Ysus to turn off 15V it probably doesn't have an enable...
        Most likely cause is a fault on the power rails somewhere, could be an issue with one of the supplies, short on Vsc/-Vy or Z-sustain.
        Need to check as many things for shorts.
        Maybe use an oscilloscope to check panel waveforms...might give you an idea.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          #44
          I don't give up on many project repairs but this one is done. taking it apart and parting out boards - I know they're all good. done swapping them in & out ! Have 3 Ysus, 2 Zsus, 3 SMPS, 2 Logic, 2 Main bds, 2 buffer bds, orig remote, stand available. Pretty confident the panel is bad. thanks to all for all the suggestions.
            Panel isn't bad, you're missing something.
            But good luck selling the parts anyway.
            • ajshoe
              ajshoe
              • Dec 2012
              • 477
              • usa
              #46
              U may b right but since no schematic or flowchart on what is shutting down Ysus be - got tired of fooling with it. I did get the plasma panel to energize for 3 seconds before the Ysus shutdown.
              • gavric
                Vizio M70-C3 Half picture is bad, main board on its last leg?
                by gavric
                Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                When tv powers on vizio V logo shows nice on whole screen. picture 1
                When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                When i click video to start playing picture goes black(like when you change...
                09-02-2021, 08:55 PM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • Tr0ll
                by Tr0ll
                Original T-con:
                First replacement T-con:
                10-07-2023, 07:48 PM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • CoinCoin88
                Garage door RX unit (Cardin S38C) does not short relay to send opening signal
                by CoinCoin88
                I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
                Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
                09-15-2025, 03:36 AM
