LG 47LS4500 backlight and sound, but no display
  • godzfire
    • Dec 2017
    • 16
    Hello everyone. Looking to hopefully get some thoughts and guidance on my beloved LG 47LS4500 TV, purchased in Feb '13.
    One day I turned it on, and all I got was a slightly white backlight display. Thinking a cable was loose or something, I checked all connections and verified also it wasn't the wrong source being chosen. The sound works just fine, the LED power light is active and responds to all remote and on-tv commands, and when I plug in a video cord to my computer, the computer recognizes the display as being attached.
    I attempted to contact LG Repair who pointed me to a small local TV repair shop. When I called, they stated it would cost a fair amount just to look at the display.
    I'm just hoping the knowledgeable folks here might have some ideas what could be going on/issue might be, and if there's any chance it's worth bringing it in. I deal with bad anxiety which can make making decisions very difficult, especially when it deals with a large monetary item, so I really appreciate everyone's educated assistance in this matter. Thank you all in advance.
    Re: LG 47LS4500 backlight and sound, but no display
    We need to pictures of the whole backside of the TV showing all the board.
    At this point you need to find out if you are getting the 12VDC at both end of the SMD fuse on the T-CON board or not.
    You do have meter and know how to use it, right?
    • godzfire
      • Dec 2017
      • 16
      Hello budm, thanks for the message. No, sorry I am not familiar with any of that. I wouldn't mind taking off the back panel and taking some pictures if that would help. One of my friends deal with electronics and might have that, what equipment specifically should I be looking for?
        You cannot do much without the meter, but still need to see the pictures to see if the T-CON is integrated with the LCD panel or not.
        • godzfire
          • Dec 2017
          • 16
          Here's some additional pictures. Let me know if you want any close up pictures on anything:
          • JT Morgan
            • Dec 2017
            • US
            I have this exact same issue. Same manufacturer date and location as well. Think this is coincidental? Just happened.
              So did you get the meter yet?
              • godzfire
                • Dec 2017
                • 16
                Hey Bud, sorry for not responding back sooner, didn't get a notification you replied. I am still trying to track down someone who has a voltage meter. Is there anything you can see from the pictures or things I can check in terms of damage or what not?
                  Nope.
                  • godzfire
                    • Dec 2017
                    • 16
                    Okay I have one of these guys to hopefully help me, if someone could tell me what I need to do/test:
                      http://en-us.fluke.com/products/elec...html#techspecs
                      http://en-us.fluke.com/products/elec...al-tester.html
                      Are you joking?
                      • godzfire
                        • Dec 2017
                        • 16
                        I'm sorry like I said I am not familiar with any of this and reaching out for help. Can you show me a picture of what meter you are talking about and provide some links?
                        • freakaftr8
                          • Oct 2012
                          • 3743
                          We need to see if your tcon is getting 12v or not. Also need to do some fuse checks. With your meter, what happens when you touch the 2 probes together ?
                          • godzfire
                            • Dec 2017
                            • 16
                            Hello freak, thanks for replying. If you mean touching the red and black ends from the Fluke meter together it makes a continuous beep.
                            If you can tell me or highlight on my pictures where I need to put the testing ends on which parts I will do it.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              You will have to remove that cover on the bottom middle board and look for a fuse labeled F something. Fuse will be located where the flat ribbon cable plugs into the tcon board. This will be the board that we're focusing on right now
                              Also I noticed the screen on your fluke meter has a pressure point does it still show a display?
                              • godzfire
                                • Dec 2017
                                • 16
                                Okay here's what I see:
                                EDIT: Yes the meter display does work and the meter itself functions fine. Tested it on some items at work.
                                  Check the resistance of that white fuse right next to the left side of the top connector.
                                  NO POWER to the TV!
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Use your red and black probe on each side that fuse with the TV unplugged
                                    • godzfire
                                      • Dec 2017
                                      • 16
                                      Okay can do, just need to know where to properly place the red and black probes to properly check.
                                      EDIT: Guessing you mean putting one on each of the gold ends. Did that, and no beep. However, if I place each of the probes on both sides of each of the single gold ends, it does beep.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Ok...
                                        Well the fuse is bad. There's your problem. Either find a way to replace fuse Or replace the board by the part number on the board
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • triplefour
                                          TCL 75S421 has sound but no backlight not even a flash
                                          by triplefour
                                          TCL 75S421
                                          PSU BOARD: 40-L402H8-PWD1CG
                                          it shows not even a flash of backlight when powering up.
                                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                          with mb connected, PSON...
                                          11-17-2023, 09:54 PM
