Philips 32PFL1335 No LED Backlight
  • mugunthans
    • Dec 2016
    • 32
    The issue just pop-up while running normally... all of a sudden display went off... but still sound works... used a flash light and could see picture so Panel / TCON status is Good also I open the Panel and tested each LED and all Good. so issue should be with in LED driver.
    Philips 32PFL1335 (LG panel K320WD2)
    I have attached the picture of boards and SCH from chinese version.
    DMM reading
    Vin - 5v
    EN - 3.3v
    VLED+ 13v
    Gate - 0v
    CS - 0v
    EC10 - 13v
    D10 - 13v
    Q3 - Source - 13v
    Q3 - Gate - 0v
    Q3 - drain - 0v
    can someone help please.
    Re: Philips 32PFL1335 No LED Backlight
    1) TV OFF, leaving all the connectors in place.
    2) Put the DC Volt meter probes on the two legs of the cap EC10.
    3) Turn on the TV and look at the meter to see how high the Voltage jumps up to before it goes back down to 13V.
    4) We also need the pictures of the whole back side of the TV showing all the boards and how they are connected together.
    • mugunthans
      • Dec 2016
      • 32
      EC10 reading jumps upto 15v and back to 13v. Full read picture attached.
      • mugunthans
        • Dec 2016
        • 32
        i'm thinking to add LED driver board...any recommendation please...
        • chestercc
          Philips TV Backlight Repair
          by chestercc
          So i'm trying to replace the LED's in a Philips TV. It's 42" with a 715g7262-p01-000-0010 backlight driver board based around an O2 Micro OZ9902CGN.
          My issue is when I replace all the LED's on one board with the new 3V 300ma ones they immediately burn out when the set is powered again. I previously tried the same thing with 6V LED's and the backlight flickered for a bit but wouldn't start.
          The original LED's which I removed which are still working start to melt and burn when given more than 3V on DCPS so I know they shouldn't be higher voltage ones.
          11-18-2022, 01:15 PM
        • ohren
          Trying to control Philips backlight manually with PWM — brightness increases with frequency...?
          by ohren
          I raised the question of whether PWM on the power board "dim" pin would be a reasonable assumption for controlling the backlight of a Philips TV (55put6101/12): https://www.badcaps.net/forum/troubl...d-tv-backlight. I didn't receive any insights there so I went ahead and tried it.
          The setup is basically:
          Rpi3 hardware PWM → 220 Ohm → NPN transistor → dim pin
          Transistor is switching the 3.5 V supply on the power board....
          12-05-2024, 11:10 AM
        • Patrick501
          Philips 55PUS6704 no picture, backlight ok
          by Patrick501
          I'd like to repair a Philips 55PUS6704.
          It turns on and you can see the backlight, hear the sound but no picture.
          When I disconnect one of the T-con cables, half of the screen turns white.
          right cable disconnected= right side white
          left cable disconnected= left side white
          When I tape like 6 or 7 pins of one cable it looks like the picture attached. I already tried another T-con board without success.
          There are no shorts on the the mainbaord and the two lcd panel boards...at leat I couldn't find any.
          Also you can notice one single...
          11-12-2025, 08:46 AM
        • ovrax
          Philips 55PUS6804/12 turn on & off (probably backlight issue)
          by ovrax
          First of all, please excuse me as I'm quite new to this field.
          I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
          I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
          The Ambilight works perfectly and stays on.
          No sounds.
          Thanks in advance.
          08-25-2024, 04:33 AM
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
