Sony KDL46XBR4.... a new "learning journey"
  • budwich
    • Jul 2015
    • 3097
    Re: Sony KDL46XBR4.... a new "learning journey"
    The tv is now fine. The "uneventful" means that there is no big deal. It is very easy to remove the side tabs on sets that don't have side edge boards which make access to the tabs a bit more difficult. Thanks and take care.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4456
      • Italy - Milan
      #62
      But you have removed the side tabs? It's not clear.. "there is no big deal".. and little deals?
      • budwich
        • Jul 2015
        • 3097
        yes the side tabs on the left side (from the front) are gone. The TV is operating fine. I don't have much experience with what to expect under a tab so I didn't want to play any more with the bottom left tab as you suggested. I was worried that I would cause even more issue and result in a totally failed set. I now have a set that operates fine for the time being. A 70 in sharp that I removed the faulty side tabs for is now 2.3 years old and running fine. The neighbor / owner thanks me every day for saving the tv for him (and his wallet).
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4456
          • Italy - Milan
          #64
          OK so not minor problems? thanks .
          • budwich
            • Jul 2015
            • 3097
            I haven't tested all the visual features (ie. 120 hz refresh, motion enhance, etc), but visually for normal viewing, the picture is fine. There may be some difference across the screen in terms of uniformity of brightness but not significant for regular viewing.
            • budwich
              • Jul 2015
              • 3097
              Although the photo doesn't do the display justice, this is the end result of the tv used as a monitor via hdmi in from a windows tabletpc. The display is as sharp as a normal monitor of this size.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4456
                • Italy - Milan
                #67
                OK, bye..
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4456
                  • Italy - Milan
                  #68
                  This video i have seen long time ago and is actual..
                  https://www.youtube.com/watch?v=9UrTVEC5LkA
                  • budwich
                    • Jul 2015
                    • 3097
                    Thanks, I am sure that there may be some way to fix the set as per your video but I wasn't willing to play with it any further and end up with a worse situation. My soldering skills / equipment aren't the best. Anyways, it has potential for some one else to try... maybe you since you indicated you have a 60 in with similar problem... good luck.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4456
                      • Italy - Milan
                      #70
                      i have no 10ohm resistor!! Bad bad...! Maybe i will try with 2 22ohm in parallel.. what a poor...
                      • Carlos#2003%
                        Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                        by Carlos#2003%
                        Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                        02-15-2024, 07:52 PM
                      • dkneyle
                        Sony KDL-46HX850 Can't upgrade/update firmware
                        by dkneyle
                        Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                        Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                        09-25-2024, 10:44 PM
                        Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                        This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                        09-06-2024, 05:27 AM
                        Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                        This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                        09-06-2024, 05:30 AM
                        Sony VAIO SVF15N1D4E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                        This specification for the Sony VAIO SVF15N1D4E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF15N1D4E boardview and SVF15N1D4E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
