(SOLVED) - Hitachi le55w806 - no backlight
  • JDC
    • May 2015
    • 273
    Issue: TV powers on, LCD blinks, and stays dark. An image can be seen on the screen with a flashlight.
    Solution: Repair/replace the single LCD strip. You'll need to tear it down to the bare metal to do it.
  • frannyjunk
    • Oct 2010
    • 82
    Re: (SOLVED) - Hitachi le55w806 - no backlight
    Where did you buy the LED strip? I can't find it anywhere. Also, are there videos or pictures on how to disassemble everything?
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • DanPoka
      by DanPoka
      02-15-2025, 05:05 AM
    • Comp_Pro
      No Backlight Macbook A1990 820-01041
      by Comp_Pro
      Hello all,
      Am trying to figure out this backlight issue with this A1990 Macbook Pro.
      Tests performed:
      There is no backlight even with a good screen.
      Backlight IC is receiving the correct support voltages.
      Fuse F8400 ok
      Current sense resistor R8400 ok
      Backlight IC is receiving 3.3V on enable pin.
      Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
      Backlight IC receiving 5V from PP5V_G3S
      Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
      I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
      05-06-2024, 10:23 PM
    • EazyBone
      Onn 100012588 backlight issue *Solved 70 inch
      by EazyBone
      Had another one of these 70 inchers from onn and was same problem as others. The picture shows but no backlight. The backlights test fine. The issue is the 450v 10uf capacitor by the backlight connector. Usually the cap bulges, the cap I replaced today for fix was NOT bulging. Replaced anyway and fixed.
      Hope this helps someone....
      11-19-2023, 06:20 PM
