Sharp LC-70LE650U Dark Spot In Screen
  • AdrianLeeCon
    • Oct 2018
    • 5
    Re: Sharp LC-70LE650U Dark Spot In Screen
    Here's a photo of what im dealing with. Not sure where to start with the fix, any help is appreciated guys, thanks again!
    • AdrianLeeCon
      • Oct 2018
      • 5
      How did you remove them?
      • geeforce
        • Oct 2017
        • 87
        Disassemble screen and remove frame around edge of panel, remove the tabs from the offending side, like peeling off a bandaid or tape. It is irreversible so do your own research, seems like your right side is bad. Lots of threads in here on it. Vizio/Sharp screens.
        • AdrianLeeCon
          • Oct 2018
          • 5
          Are these the tabs i should remove? Do i just peel them off and the affected side and then try out the display? Should I disconnect anything else?
          • mmartell
            • Oct 2013
            • 3189
            In your pic I see all the tabs except the affected one. Visually inspect it to see if it's burnt or run the set and put your finger on it. If it's getting super hot as compared to the rest then yes, remove all tabs on that side.
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              #26
              I had the same symptoms as the OP on a LC-70LE650U. Dark spot towards the middle of the screen and a smeary, slow responding picture on the left side. I removed the left side driver boards and the picture was restored.
              Just trying to add to the knowledge base.
              They call me......."threadkiller"
              • scubacamper
                Sharp Aquos LC-70C6400U Half Screen Dark
                by scubacamper
                I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                05-03-2025, 12:19 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • EazyBone
                Sharp LC-65Q620U White Screen
                by EazyBone
                Another TV topic!!
                I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                08-21-2024, 12:56 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
