My LG 60PA6500 would turn on automatically when plugging it in. The screen would be backlit but nothing was visible, no menu and you couldnt turn off the tv. I was testing the voltages on the X board I think when I shorted it out. Now nothing happens and all I read is 120Vac at the main board connection.
Lg 60pa6500
by Rekoo1997Laptop Model: DELL Precision 3520 Motherboard: CDP80 LA-E152P Rev 1.0 (A00)
Issue: The laptop powers on automatically after being shut down.
Actions Taken by Technician:
BIOS reflashed
Intel ME region cleared
Result: Issue still persists
Additional Observations:
Power button reads 3.3V (normal)
The problem occurs both when running on battery and when connected to AC adapter... -
by unimatrix93Hello everyone, I have a constantly blinking Inexive LED TV.
Display is: VES390UNVA-2D-N01
Mainboard: 17MB97
PSU: 17IPS71
The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help.... -
by _max_Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
Power cable and HDMI cable checked.
No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
by dit3Hello everybody,
I got HP ProBook 455 G7 which originally turned on partially(fans on 100%) and hen off after 8 seconds, with AC diode flashing orange and last flash white. This behaviour stayed for a while, but before I realised that there is power delivery issue and not BIOS problem, laptop started to automatically turn on after 2 seconds when in turned off, kept power cycling. So after I fixed shorted cap and burned ferrite bead, laptop turned on fine and booted to windows.
Now, laptop can be turned off and it stays like that... unless you plug adapter again, which triggers... -
by Ziliconi've been working on the above PC for some time now, but the fault remains unsolved.
Behavior:
less than 2 weeks after the battery and keyboard of the pc were changed, the pc started crashing and restarting on its own. it keeps doing that at approximately an hour intervals, at times, it becomes shorter than that.
When it crashed, there was no BSOD of any kind; the power button did not misbehave; the pc did not overheat either.
what I have done:
cleaned the ME of the BIOS firmware, changed the thermal paste, removed all peripheral devices- (keyboard,... - Loading...
