Toshiba 42UL863 blown fuse
  • Babbar
    by Babbar
    04-12-2024, 01:12 AM
  • drscoot
    HP X360 convertible battery blown fuse error, not charging
    by drscoot
    HP Modelnumber: 14-dh0061nb​
    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
    All these 3 batteries are charging...
    12-15-2023, 05:54 AM
  • beetle1303
    Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
    by beetle1303
    I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
    On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
    01-13-2025, 08:49 PM
  • semiRocket
    Toshiba 37bv701b power supply main rails
    by semiRocket
    The set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
    I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
    Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious...
    10-26-2025, 01:55 AM
  • cmlewis89
    LG 47LB5DF blown power supply board
    by cmlewis89
    Hi folks,
    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
    09-03-2024, 07:50 PM
