Samsung UN55KU6500 Concave Dark Vertical Bands..
  • Michale32086
    • Nov 2011
    • 1453
    Got one of those newer concave Sammys...
    It had no power and I determined it was a bad Main Video board..
    Got a replacement Video Board in and the TV did come on and a picture did show up. Which tells me my assessment was accurate.. Yea Me!!
    Unfortunately, there is a new problem..
    Dark vertical bands...
    I am hoping I just got a bum Video Board, because the only alternative I can see is a bad board where the tab bonds are secured to the display panel.. There is no TCON....
    Can anyone confirm one way or the other??
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Samsung UN55KU6500 Concave Dark Vertical Bands..
    since the missing lines cover the whole screen and are evenly spaced, i would say that your replacement main has issues. you could reseat the lvds, but i don't think that will have any effect.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Michale32086
      • Nov 2011
      • 1453
      Yea, I cleaned and re-seated the LVDS..
      Good to hear it's likely a Main Board issue.. Have a replacement board en route..
      Thanx...
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        by ohren
        09-08-2023, 05:24 PM
      • C152Heavy
        by C152Heavy
        Summary for TL-DR readers:
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
        09-07-2024, 05:50 AM
