Sharp lc-70le650u
  • goldfingeroo7
    • Nov 2017
    • 7
    Sharp lc-70le650u
    Having this issue with my tv. Left side of the TV is good. Right side is not so good. Is this fixable? Already tried replacing the TCon board but it did nothing.
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Sharp lc-70le650u
    Sense I see that you have the bezel off the screen already why don't you try disconnecting the little white flat ribbon cable that goes from the bottom boards to the side edge boards at the bottom left corner in a look at the screen and see if those lines are still there.
    • freakaftr8
      • Oct 2012
      • 3743
      Also try swapping tcon cables to panel from left side to right side. Also does it look like there might be any damage to the frc ribbons going into the panel under the affected area? Especially look for signs of liquid damage.
      • goldfingeroo7
        • Nov 2017
        • 7
        I have done that and the result is the image above. It didn't fix the vertical line/color issue on the left.
        • budwich
          • Jul 2015
          • 3097
          you "done what"? swap cables? disconnected cables? what exactly was the result of each step that you tried?
          • freakaftr8
            • Oct 2012
            • 3743
            Right. Which cables. Did you try swapping ribbons on the T con or did you tried disconnecting the little elbow corner cable on the bottom of the panel where it goes into the side driver boards?
            What I think he is referring to is using the white flat ribbons from the T con it's swapping the ribbons to the other side checking in verifying if there are any broken or failed pans within the ribbon cable. If it were a bad rep and it would be make this symptom on the opposite side by swapping the cables. However I would only assume by the looks of this there may be some kind of liquid intrusion to the lower FRP boards underneath the affected area. Usually this will present its self with white crusty looking deposits all over the board and the ribbon connections would be destroyed.
            This will especially happen if somebody cleaned the screen with windex and let it run down into the bottom of the panel
            • goldfingeroo7
              • Nov 2017
              • 7
              Sorry guys. Here are the steps I took.
              1. Replace the t-con board. No change in the screen.
              2. Only connect the right ribbon cable. Left side of screen was white. Right side looked great.
              3. Only connect the left ribbon cable. Right side of screen was white. Left side was messed up.
              4. Found this forum.
              5. Removed the black outer piece of plastic to get access to the ribbon cables.
              6. Disconnected the left side ribbon cable. (The white cable on the lower left of the screen.) This fixed the rolling lines on the entire screen when both connectors of the t-con where connected. But not the color vertical color lines from the screen shot above.
              7. Swapping the ribbon cables on the tcon board had no change in the output.
              No water damage on the screen anywhere. This is one of a pair of 70" TVs used in a corporate environment. I was able to fix the other 70" TV with a USB firmware update. That one is a LC-70LE640U and it works great now. They both were going to be thrown away but I was able to get them to try and fix. Got them for free too so not too important to try and revive.
              Thanks for your help. Would love to get this working if possible though.
              • budwich
                • Jul 2015
                • 3097
                the water "damage" isn't on the screen... It appears on the edge boards usually along the bottom. From you "testing" and pictures, the lower left edge boards and tabs associated with that section of the screen may have an issue. Check the tabs near where those vertical lines are to see if you can visual see any thing about those connections (compared to others).
                • goldfingeroo7
                  • Nov 2017
                  • 7
                  I didn't see any water damage on the bottom portion of the screen where the ribbon cables connect to the lcd display. There are 4 connectors on each side. When I get home from work, I can take a picture of this. Checked the caps too and they didn't look "burned" out. They are hot to the touch when the TV is on though.
                  • budwich
                    • Jul 2015
                    • 3097
                    :-( on the caps. Possibly some may be done. You should check / compare them with others on the "other side" both in terms of "hot" but also doing a "power off" resistance / capacitance measurement maybe...
                    my guess is that there is a tab issue near that side but could also be a cap problem. I do believe, in the past, someone found a cap issue on an "equivalent set" and did an "on tv / board replacement" since the boards couldn't be removed. You might get lucky herein also.
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • howardc64
                      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                      by howardc64
                      • Prior owner tried a replacement main board. No difference.
                      • Samsung 2x red blinking standby LED = panel fault
                      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                      07-19-2025, 10:54 PM
                    • Stephen
                      A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                      by Stephen
                      Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                      05-29-2025, 10:35 AM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
                    • ravi_1617
                      HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                      by ravi_1617
                      Hello to all ,
                      I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                      Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                      on external VGA port image is perfect /normal , Attached image...
                      07-25-2025, 12:07 AM
