Sony Bravia kdl46ex500
  • SDeuce
    • Dec 2016
    • 15
    I was driving to work yesterday and noticed a TV next to the curb. I stopped and picked it up. This will be my third TV repair, and I still have a lot to learn. I plugged the TV in and got a solid red indicator light, I pushed the power button and got a green light, I see nothing on the LCD panel, but I hear the Sony boot up sound, then it restarts, 3 times and then shuts off. Im getting six blinks on the red light. I pull the back off and start with the power supply, and here is what I found.
    Wall voltage to board: 120vac
    Fuese : Good
    standby voltage: Not good (4.66 vdc)
    Power on voltage: Not Good (4.7 vdc)
    Backlight on voltage: Not good (4.7 vdc)
    At this point I stopped checking voltages and started looking for visible signs of component damage. Nothing looked to be burned/discolored. No tops of caps bulging.
    So..... I need some reassurance in my thinking that the problem is in the power supply. It would be easy to get a new board and be good (assuming my thinking is correct and it is the power supply) Id like to delve deep into it and try a component level repair. I dont know I have the tools needed or the know how.. Where do I start?? there is some for of voltage regulation problem.
    on a side note, I did see thru the back, while pushing the power button, the back lights trying to light..
    Im unsure if its within the scope of someone like me doing component level work...
    Re: Sony Bravia kdl46ex500
    Are you sure your DC Volt meter is OK?
    Power on voltage: Not Good (4.7 vdc) Is the pin label as PS-ON, if it is then it is OK. It is the command signal from the main board, > 2vdc = ON < 1V = OFF
    Backlight on voltage: Not good (4.7 vdc): BL-ON?? It is the command signal from the main board, > 2vdc = ON < 1V = OFF
    At this point we cannot help you much since you did not provide good clear pictures of YOUR boards.
    I will see what the 6-blink error code is, I believe it has to do with backlights.
      https://www.badcaps.net/forum/showth...500#post614570
      • SDeuce
        • Dec 2016
        • 15
        I was saying the voltages were bad because on the broad it says standby volts 3.3 vdc and the reading I was getting was 1.3vdc higher than that. Same going for the power on volts being 12vdc but the reading of 4.6 volts, and same for the backlight labled 12vdc, but only getting 4.66vdc. I have checked known voltages with my meter and not had any issues. All the voltages of 4.65 something were the same within a few milivolts. The BL on reads from 4.6 - 0 vdc when trying to light the bulbs. All of the measured values coming from the 15 Wire sprout connector going to the main board. Maybe im not understanding. I will try and post some pictures, however I'll be going out of the country for several days.. Thank you for your input
          Are you 100% sure that the batteries of your meter is good? When batteries are low the reading will show higher Voltage reading than it should.
          • freakaftr8
            • Oct 2012
            • 3743
            Look for r602d on power supply.
            • freakaftr8
              • Oct 2012
              • 3743
              Sorry wrong board
              • PopsCaps
                Sony Bravia KDL-40V2500 that will not power on
                by PopsCaps
                I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                I do not hear any sound and I cannot see any backlight.
                I have tried disconnecting every cable on each board one at a time to see if anything changes.
                The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                03-25-2025, 11:23 AM
              • SkishyIshy
                Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                by SkishyIshy
                Hey All,
                I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                03-17-2021, 11:44 AM
              • justin35
                Sony bravia kdl-43w755c - boot loop
                by justin35
                i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
                from what i read online it looks to be an emmc issue…
                i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
                i took out the board and say an samsung 16gb emmc
                i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
                i could try to put one instead of the 16gb one, but will it work?
                where do i get the software from?
                any help will be much appreciated!...
                03-06-2024, 12:26 PM
                Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
                Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
                10-16-2024, 05:15 AM
              • Ihandyrepair
                sony 55X850D black screen no front white or red led light.
                by Ihandyrepair
                Hi guys
                strange one
                I have a dead Sony 55X850D
                when plug in, black screen, no front white or red LED, no back light no screen
                Voltages I get
                3.3v LD/power and main board
                reg 12V
                reg 19V
                3.3v on power on pin
                no Tcon on
                no tcon 12v
                no BL_on
                I do get BL_ERR 2.0v
                I tried to bypass it by ground it but still get same symptom
                I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                or is possible the chip next to...
                08-07-2024, 04:58 AM
