SAMSUNG UE65ES8005 with colored horisontal lines
  • olegeisler
    • Dec 2016
    • 100
    • Denmark
    Hi All
    This huge TV had its mainboard replaced in June 2017 ( HDMI input failed ) - the mainboard was new, not a used replacement from Ebay or similar. Worked great since then.
    Now, the owner sent me this picture ( see attachment ).
    And of course the TV runs wothout any issues after moving it to my place
    Anyone with any clue what the most probable issue could be ?
  • olegeisler
    • Dec 2016
    • 100
    • Denmark
    Re: SAMSUNG UE65ES8005 with colored horisontal lines
    FYI it is the mainboard. TV started failing after 3-4 hours use, rebooting and displaying the horisontal lines.
    FFreeze spray on main processor and the issue goes away.
    Another mainboard..............
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4333
      • Italy - Milan
      Check PSU ripple, can be the main culprit..
      • olegeisler
        • Dec 2016
        • 100
        • Denmark
        Thanks - but I already checked PSU, all voltages are corret, and ripple seems OK.
        • joe-joe
          • Aug 2016
          • 37
          • BelgiĆ«
          what is de BN 94...... number of the mainboard?
          • olegeisler
            • Dec 2016
            • 100
            • Denmark
            Bn94-6197r
              09-07-2024, 05:50 AM
            • Falki
              Colorful LCD Vertical Lines on Samsung ue55es8090
              by Falki
              Hello there, ive recently found an older 55inch Samsung SmartTV.
              A similar issue has been posted as well but also with no actual response ...
              Today, 04:19 AM
            • Rubenlily
              Samsung QE50Q67TAU - horizontal lines
              by Rubenlily
              First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
              I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
              I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
              I'm no expert but I've done the tape...
              08-16-2023, 01:12 PM
            • jeyoung12
              Samsung QN50Q60t lines on screen
              by jeyoung12
              Hi all
              I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
              My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
              This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
              It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
              So....i don't know what end of the C ribbon to work with...
              02-26-2024, 10:38 AM
            • bohaboha
              ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
              by bohaboha
              Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
              04-19-2025, 01:47 PM
