EU40F6400 startup failure
  • aurelienr
    • Nov 2017
    • 25
    • France
    Re: EU40F6400 startup failure
    No picture, no backlight....but sound works and I ear I can scroll into the menu with the remote...
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4289
      • Italy - Milan
      There is a remote possibility that the software of this particular model, but is no common on Samsung, switches off the B.L. if it senses a problem on the tcon, that has an i2c bus communicating diangostic to the mainb., so i think since mainb. are expensive, you can troubleshoot tcon, but i need a big picture of it without the shield, i think you use a bad method of posting images, click on the page bottom "post reply" then click on the paper clip, it appears a window , you can click a button to select the path of the image, then click upload, wait for the message then "close window" button, now select the arrow neat paper clip so link the photo in your text.
      • aurelienr
        • Nov 2017
        • 25
        • France
        Done
        • aurelienr
          • Nov 2017
          • 25
          • France
          I check the tantalum caps (that often fails by creating a short), the black one on the top (marked NEF/EN7) is in shortcut. I could unsolder it to check if this is really the cap of another part that is in shortcut...
          • aurelienr
            • Nov 2017
            • 25
            • France
            In a previous post I said that The LED3 was off and on the PCB I see that it is connected to the AVDD plane. It's likely that the cap I measured in short is connected to this plane, explaining why LED is not on. If fuse does not trigger that means there is either a current limiting device (but I did not detected any overheat on any component), or simply that the AVDD power is disabled in software for any reason (short protection for example).
            • aurelienr
              • Nov 2017
              • 25
              • France
              #26
              I ordered a new cap, I will test it tomorrow...if nothing change, I will try to find a replacement board...
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4289
                • Italy - Milan
                #27
                Hi, sorry i was doing other things and following an ebay auction (won a broken smart tv!), you better wait for help before ordering parts cause shipping is usually expensive, the AVDD plane goes directly to the panel via connector, so you better try voltages with the 2 flat cables detached, not only, it goes also to the Gamma corr. chip, that is one of the 2 medium chips, 1 on the left 1 on the right (mainb. con. on bottom), so you have to locate with multimeter continuity, which black square diode is connected from the cathode (band) to the positive of the tant. cap (band), done this you must unsolder it and unsolder the cap., then check the cap for short, if it's good connect the diode anode to the board with a wire, just for testing purposes, then the cap + to the diode cathode and the cap - to the GND, now you can test AVDD tension, it must be around 15V. To be sure on which chip contains Gamma corrector, you can, with diode unsoldered, provide about 12v to the avdd plane, if you see a chip that starts smoking then that is the chip to be change but is an hard work, for info got youtube "QFN soldering"....
                OR, if you arent able to do theese tests, at least try the avdd voltage with panel disconnected, if is not ok unsolder the cap, if is ok, change tcon.
                • aurelienr
                  • Nov 2017
                  • 25
                  • France
                  #28
                  Don't worry i'm freelance electronic engineer I've ordered the part in another scheduled order. But I have a lot of work and I forgot to unsolder the cap to test it alone, shame
                  Of course the measurement has been done with all cables disconnected.
                  When powering on, the AVDD was obviously 0 because its LED was off ( but I did not measured it).
                  • aurelienr
                    • Nov 2017
                    • 25
                    • France
                    #29
                    I have unsoldered capacitor, it is not in shortcut. But on the board I measure a resistance of approx 3 ohms between AVDD and GND. Since you told me I should read about 12V on this plane, that would represent a 4 amp current, I don't think it is a normal current for this board (especially if it comes from the LVDS cable) !
                    I think I have found a Tcon board for repairing for 30 euros, I will try...
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4289
                      • Italy - Milan
                      #30
                      "Since you told me I should read about 12V on this plane"
                      No i've said 15v.. so 5 Amp.
                      • aurelienr
                        • Nov 2017
                        • 25
                        • France
                        #31
                        I changed the Tcon...still no change, same bug....
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4289
                          • Italy - Milan
                          #32
                          It's so sad.. maybe this Tcon has something new from older ones that i don't know, maybe some voltages on tcon lacks due to no colour data and/or i2c comm sent from mainboard?
                          E-ehm... on the post #18 i expressed myself bad, i wanted to say if you see the image pointing a lamp to the screen ' cause backlight is off and you have to provide light externally... i apologyze for that, big error...
                          • aurelienr
                            • Nov 2017
                            • 25
                            • France
                            #33
                            Not 100% sure of new Tcon functionnality, was sold as functionnal but I can't be sure (only 40 euros on ebay).
                            The screen is really blanck since, as I said before, I cut one of the PWM line of the cable between MB and PSU, so that the internal pull up resistor on the PSU force one part of the backlight to be on (and it works, but nothing displayed).
                            • aurelienr
                              • Nov 2017
                              • 25
                              • France
                              #34
                              No idea of what I could do to check MB functionnality ?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4289
                                • Italy - Milan
                                #35
                                On the post #5 you listed PSU pin voltages, Capleaker have told you to measure with mainboard attached, but it's not possible that backlight is not ON if the BLU is high, i have in repairation in my house a Samsung 46" led tv, with the same pinout, without main attached the ON signals are pulled high internally. Surely you have a low BLU, then.. why? It's a strange behaviour, really never seen by me, i'm only suspecting again for the tcon since i think there's no subtensions generated on the main that affects only lvds video out and not audio, also a cpu detaching ususally is not all by a shot, therefore it ususally works sometimes or for some seconds at powerup. Maybe i will try to dowonload Serv. manual but i'm too busy and nowadays Sams manuals are very empty of useful infos. Bye.
                                • aurelienr
                                  • Nov 2017
                                  • 25
                                  • France
                                  #36
                                  With new Tcon problem still here...µI checked AVDD to GND resistance, it seems normal (several kOhms) on new board comparing to the short measured on my Tcon, but changing the board did not solve the issue.
                                  I already spent too much time on this sh**, I bought a new TV and will try to sell the valid Tcon, the PSU and some other parts on ebay...
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4289
                                    • Italy - Milan
                                    #37
                                    I hope new tv is not Samsung, which brand is?
                                    • aurelienr
                                      • Nov 2017
                                      • 25
                                      • France
                                      #38
                                      huhuhu
                                      samsung
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4289
                                        • Italy - Milan
                                        #39
                                        No way!
                                        • gaelican
                                          Odyssey G9 Neo backlight partial failure.
                                          by gaelican
                                          I have an Odyssey Neo G9 that I was working on for a separate issue. After removing the motherboard and putting it back a few times I noticed that the lights on the display have stopped turning on altogether. I was able to determine that when the middle section for the backlights is disconnected, then the left and right side turn on, indicating that the fault is obviously in that area.
                                          After closely inspecting the mainboard I noticed that on the back side of it a few capacitors have been partially moved, one fully knocked off. I replaced the missing one with a new cap with the same...
                                          02-27-2025, 02:39 PM
                                        • howardc64
                                          Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                          by howardc64
                                          Problem
                                          Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                          Model & Board Pics
                                          Conflicting Spec
                                          Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                          https://www.shopjimmy.com/vizio-gj-2k1...
                                          10-10-2024, 01:16 PM
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • howardc64
                                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                          by howardc64
                                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                          • Backlight on, no image
                                          • Disconnect right buffer board (view from front), left side display comes on
                                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                          • Buffer board is pretty simple
                                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                          07-11-2025, 04:04 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
