Philips 32pfl3404 - problem
    i have this 32pfl3404, and when i turn it on they need a couple of minutes to show picture. It show's some grey lines and shadows after a few time show picture.
    I open it and i take down allmost all caps to measure it, some ahe more than 20% diffrent uF than they should have. So i replaced it with new. I only didnt replaced the big cap on board. I get it together and turn it on. And the picture show quicker only a few seconds after turn on. Then was some time okey. But now is the same problem, and need some time to turn on. What to do ?
    Re: Philips 32pfl3404 - problem
    Did you replace with low esr caps?
      Yes, with the same as were inside
        Heat up the main board with an hair drier and see if that fixes the problem. Maybe there are bad caps on it too.
          The t-con is the culprit, seen a lot with defective t-cons of this model. In the worst case the display itself is defective
