Vizio P552Ui-B2- right half is black & white
  • jason123
    • Oct 2015
    • 1083
    I am hoping someone here had seen this before.. just got this TV that seems to have a black & white picture on the right half and decent on the left half. See photos. Any idea where to begin? is this a bad panel or TCON?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Vizio P552Ui-B2- right half is black & white
    Is this a LCD or PLASMA Tv?
    • CapLeaker
      Leaking Member
      • 8321
      It's a LED TV.
      unplug one of the ribbon cables that go from the TCon to the panel, check the picture, then vice versa. Is the dark part of the screen sluggish to respond when you watch something?
      • jason123
        • Oct 2015
        • 1083
        Thanks.. unplugging either ribbon to TCON causes it not to turn on. No LED activity if either ribbon cables i unplugged. Just light flickers and that's it.
        • budwich
          • Jul 2015
          • 3097
          put on a known video test pattern so we can see something that isn't so busy. It doesn't look good. I am surprised that the set doesn't turn on... but maybe in newer models, vizio has come up with some protection "scheme" to save things.
          You probably need to provide some picture of the back of the set so we can see the configuration layout and cards involved.
          • CapLeaker
            Leaking Member
            • 8321
            Then turn on the tv first, then unplug one of them 2 ribbon cables that go ftom the TCon to the panel.
            • Raulnn
              TD Systems K50DLG12US half black and half white screen
              by Raulnn
              good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
              By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
              01-20-2024, 04:49 PM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • brad2157
              Vizio E70-E3 Two white vertical lines
              by brad2157
              I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
              Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
              Replacement main board - Boots up fine, but starting...
              12-13-2021, 05:11 PM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
              MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
              This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
              09-06-2024, 07:46 AM
