Sony KDL-60EX700 bad panel right?
    Re: Sony KDL-60EX700 bad panel right?
    So the problem is solved by re-installing the original T-CON and the Original Main board?
    • budwich
      • Jul 2015
      • 3097
      I think the only problem was "lack of eye glasses"... :-) especially on the lvds cable.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4544
        • Italy - Milan
        connector on lvds cable sometimes losts full contact even if it remain attached, a reinstert of it already restores full image but i think it's better to clean it and also attach kapton tape.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4544
          • Italy - Milan
          This is a OT question for Tom and others, don't want to open a new thread for a little thing, i have a Sams led tv's mainboard hit by lightning strike, the HDMI connector is fried, where do you buy those elevated connectors, smd, totally 10mm high with through hole shield pins? In the web i found none, not italian component resellers nor EBAY / Aliexpress.
          • iglitare
            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
            by iglitare
            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
            Backlight seems to work, Sound (Setup menu after reset) works.
            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
            With my small knowledge i would think at least the cables are good.
            Can this happen because of a bad tcon board?
            Or is it always a bad/shorted...
            09-04-2025, 07:13 AM
          • rimwall
            Sony KD-65x7500D - double image - Tcon or Panel?
            by rimwall
            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
            11-18-2025, 02:09 AM
          • r3vsEngIT
            Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
            by r3vsEngIT
            65x900h with the panel from a 65x930d.
            900H: model yr 2020, Samsung panel
            930D: model yr 2016, Innolux panel
            spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
            the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
            07-11-2023, 11:11 AM
          • guidodroid
            Bad Panel in Sony Bravia X850G
            by guidodroid
            Hello all,
            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
            The issue is not as bad as others that I've seen around, but is indeed noticeable...
            03-19-2022, 12:08 PM
          • PlanB
            Sony KDL-55W828B Hotspot in LCD panel
            by PlanB
            Hello everybody,
            I need your expertise if my asumption about the failure of this TV is correct.
            A Sony KDL-55W828B only shows vertical red stripes that vanish to the top when switched on.
            When only the right side of the LCD is plugged into the T-CON board the right side shows a good image, while the left side is white.
            When only the left side of the LCD is plugged into the T-CON board the LCD shows a complete white image.
            I checked some signals on the T-CON board but was not able to find something strange. Then I checked the the caps...
            02-05-2022, 09:46 AM
