T240 inverter and resistor get hot again
  • Nol
    • Nov 2017
    • 12
    • Netherlands
    Hi, my T240 had the well know 2 seconds problem and I change the inverter.
    But when I open the monitor I saw that the R301 has been very hot, it was burned under the resistor so I change that too and replaced by a 390K-5W resistor.
    It has been so hot that even the trail at the backside came loose
    Monitor works again and keep working for 2 days now but I smell something so open the monitor again and both inverter and resistor get very hot again.
    Because they are very close to eachother I think it is the resistor that smell
    Does anyone know what the problem can be ?
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: T240 inverter and resistor get hot again
    i would check the resistance on the outputs of the transformer and also check the ceramic caps as well.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • Nol
      • Nov 2017
      • 12
      • Netherlands
      I check all resistors because there not so much
      R101 = 35,8K
      R103 = 4,5
      R104 - 28,2
      R105 = 72,3
      F301 = 4,3
      I don´t have tools to check caps but they look good
      This is my board
      • petehall347
        • Jan 2015
        • 4438
        something drawing the current . turn down brightness first see what happens . put that resistor up off the board .
        • Nol
          • Nov 2017
          • 12
          • Netherlands
          I turn down the brightness but that did not solve the heating, resistor and inverter still getting hot.
          In the first time I solder the resistor in a higher position but that did not solve the heating problem.
          Even that, I have not so much space so I could not get it higher then ±3mm otherwise the steel cover put it down.
          My most important question is : is it not the lamps that take to much power ?
          If that is not the problem then I can buy a new board
          • petehall347
            • Jan 2015
            • 4438
            whatever is after the resistor is drawing too much current . i dont have the schematic . maybe a shorted capacitor .
            • Nol
              • Nov 2017
              • 12
              • Netherlands
              Maybe a wrong resistor
              I measure the bad resistor as a 390K but after comparing 2 pictures it could be a 190K.
              Maybe you can take a look ?
              • R_J
                • Jun 2012
                • 9588
                This may not be exact but should be close, its a BN44-00226C, IP-54155B
                looks like it is a 390K
                • Nol
                  • Nov 2017
                  • 12
                  • Netherlands
                  Thanks a lot, I don´t know if it depends which inverter (T301) is on-board ?
                  I have the TM10160
                  • R_J
                    • Jun 2012
                    • 9588
                    The schematic is slightly different, looks like its for a Samsung 2494lw,2494hs,2443bw
                    It could be that one of the small blue caps are bad or the the ccfl's are drawing more current than when new. The original resistor was still good but was over heating the board, could be just due to poor design and lots of use???
                    • Nol
                      • Nov 2017
                      • 12
                      • Netherlands
                      OK thanks again.
                      I think it could be too many thinks that heat-up the resistor and inverter even I think that the inverter will be extra warm when the CCFL´s are on but the resistor should be some kind of cold
                      This took me a week now to find out what is the problem and I have to make a decision.
                      I think I take the change to order a new board so that I know that the board is OK and keep an eye on the resistor and inverter.
                      Thank you all so far and I come back to you
                      • attainteddragon
                        • Apr 2013
                        • 764
                        • australia
                        unfortunately if the ccfl's are the cause for the excessive heat, then a replacement board will end up having the same issue that you are having now.
                        • Nol
                          • Nov 2017
                          • 12
                          • Netherlands
                          Yes I know but I have to take that chance and if it happen again I have to change the CCFL´s too.
                          I have not check where to buy them but I believe they are not that expensive
                          • petehall347
                            • Jan 2015
                            • 4438
                            you could buy a cheap ccfl kit and see if it gets hot running the ones in the panel .
                            • Nol
                              • Nov 2017
                              • 12
                              • Netherlands
                              I just receive the new board but even it is the same type (IP-54155A) it is differend and my question is can I use this board ?
                              I see them a lot for the Samsung T240 but I am not sure if it will work properly
                              • attainteddragon
                                • Apr 2013
                                • 764
                                • australia
                                if your connectors are the same, you should have no issues at all from what i can see.
                                • Nol
                                  • Nov 2017
                                  • 12
                                  • Netherlands
                                  Thank you I try it and let it know.
                                  • Nol
                                    • Nov 2017
                                    • 12
                                    • Netherlands
                                    Since I order the new board I had the old board connected but I did not close the backside cover so it is open on the backside and it works fine and the smell is almost gone.
                                    Inverter and resistor still get hot
                                    Now I connect the new but different board and same problem came on, after ±2 seconds backlight goes off.
                                    So I think the new different board does not work properly in my Samsung T240 and I contact the seller about it and I connect the old board again and again it work well
                                    • attainteddragon
                                      • Apr 2013
                                      • 764
                                      • australia
                                      pity you don't have some spare globes. i think that would be a great way to test it out.
                                      i have seen the connection come loose on the ccfl itself. ideally you would have to strip it completely down, but not sure if you want to go that far yet.
                                      • Nol
                                        • Nov 2017
                                        • 12
                                        • Netherlands
                                        Just an update, TV still works fine with the old board and it does not get so heat anymore
                                        I still have the new board which is different because the seller don´t want it back but refund me the money, respect for this solution.
                                        I think to keep it as it is with the original old board
                                        What is your advice ?
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          by mikey5791
                                          Hi to all forum members,
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
                                        • chth96
                                          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                                          by chth96
                                          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                                          Since then, This AC/DC adaptor have been out of order.
                                          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                                          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                                          And Is there any possibility that it will suddenly explode as well as to be out...
                                          12-03-2023, 04:40 AM
