T240 inverter and resistor get hot again
  • petehall347
    • Jan 2015
    • 4439
    Re: T240 inverter and resistor get hot again
    if it seems ok give it a good long testing . also cycle power to be sure .
    • TEDDIBEAR
      • Oct 2014
      • 45
      • england
      I would not use a wire wound resistor in that position, as the circuit is high frequency, you could check resistance of windings on inverter transformer if all ok and read continuity then check for bulging electrolytics, and those little blue capacitors they do fail, reason for that resistor getting hot is probably due to oscillation, a wire wound resistor would make the problem worse, You could have a shorted turn on the inverter transformer of course.
      I would not use the receiver if components are running hot, you have not said if the board has been burnt to charcoal if it has it could be tracking.
      • jinu_j
        by jinu_j
        Hi
        05-03-2025, 10:51 PM
      • mikey5791
        by mikey5791
        Hi to all forum members,
        12-26-2024, 04:55 AM
      • MidnightRoller
        Can a resistor lose resistance after hot air?
        by MidnightRoller
        I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
        I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
        02-02-2022, 11:46 PM
      • artvandalai
        What resistor ohm will work better to repair this waterpik?
        by artvandalai
        The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
        01-05-2025, 04:10 PM
      • chth96
        Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
        by chth96
        I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
        Since then, This AC/DC adaptor have been out of order.
        But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
        After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
        And Is there any possibility that it will suddenly explode as well as to be out...
        12-03-2023, 04:40 AM
