Vizio D65U-D2 Intermittant Back lights
  • johns1mj
    • May 2015
    • 242
    Started inspecting a d65u-d2 for losing picture while watching. Using a flash light I was able to determine a backlight issue. It could take 5 minutes or all day. Once it does it you can get it to repeat fairly quickly. Every time you shut off the tv and turn it back on the lights come back on atleast for a minute. Since I knew it was a lighting issue I started testing at the inverter board. All voltages into the inverter board tested the same when the backlight were on or off. Voltages out did vary. With or with out the back lights on the White and Red pairs of wires all tested around 24 volts. With the back lights on the black wires vary between 3 volts and .5 volts. With the backlights off all but one carries 6.8 volts. The 3rd black wire in from the left on the left connector continously varries voltage.
    I suspect bad led strips. I believe the led is getting warm and shorting out. Any opinions?
  • CapLeaker
    Leaking Member
    • 8118
    Re: Vizio D65U-D2 Intermittant Back lights
    This TV doesn't have an "inverter board" since it is a LED TV. So it has a LED driver board.
    I think that one of the LED's in the backlight is failing. So what you can do here is to turn down the backlights in the menu to next to nothing and see if the backlights stay on longer. IF that is the case, you have to tare down the panel and replace the failing LED(s) or the LED strip(s).
    • johns1mj
      • May 2015
      • 242
      I unplugged half the led driver board, the white and black side stays on and the red and black side turns off. I turned down the back lights and it has been on for a couple hours now with both plugged in.
      • CapLeaker
        Leaking Member
        • 8118
        I figured... so you have a bad LED somewhere on those backlight strips.
        • johns1mj
          • May 2015
          • 242
          Took it apart and found 1 led that was bad. Repaired the strip and it is working fine now.
          • CapLeaker
            Leaking Member
            • 8118
            good to hear you fixed it!
            • howardc64
              • Jun 2017
              • 590
              Have one with backlight only staying on if turned down really low (like 30%) much brighter will cause the backlight to shutdown.
              Ran a youtube white screen test and 1 dead row of LED was visible.
              This TV has 16 LED strips (8x 3V LED each strip). Have a LED driver board that supply voltage to all 16 strips independently with 2 connectors. Each connector responsible for 8 strips and 1/2 of the screen. Can use a LED tester to confirm bad LED strip and not the driver board at these connectors.
              LED driver board will also allow TV to run with 1/2 screen of backlights. Useful for debugging.
              Replaced all 16 strips (new strips were slightly brighter and I suppose will last longer than keeping the old strips that are still good)
              • tennno`
                RCA LED46C45RQ,Sound but no Back lights
                by tennno`
                Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
                Has All voltages coming from main board.No voltage going to
                Back lights from power board.Have no Schematic.Back lights work when
                Led Back light Strip tester is used.Tester shows 110 volts from each
                side.Also if you use the side controls and use the vol +or- tv shuts
                down.
                Thanks for any help
                04-10-2022, 03:34 PM
                Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                by sam_sam_sam
                This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                I am comparing them to a brand new one that I installed
                The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                I going to let it run for several days before I remount back on the wall next to the...
                09-05-2024, 06:48 PM
              • Musictuff
                70UH6350 Back lights
                by Musictuff
                My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                04-09-2023, 11:45 AM
              • giddyupngo
                Backlight replacement mess, Vizio V505-G9
                by giddyupngo
                Hello, I would appreciate your expertise on this. I have about 5 years experience with copier repair, so I have done a lot of board and component replacement. This is the first LCD TV I tried to repair, and it really humbled me. The issue was that on power on the TV power light would go on and then fade out seconds later, and there was no image at all, screen stayed black.
                I thought this meant there was a power board problem, not realizing that the power light fading out was by design, probably so the light would not distract the TV watcher. This is not my TV, so I wasn't familiar...
                02-09-2023, 09:14 PM
