Led Backlight Repair
  • satinser
    • Oct 2012
    • 214
    • uk
    Getting an ever increasing number of backlight repairs lately. I would be interested to know what others do as regards whether or not they replace delayed start indvidual LED on some strips. Upto now ive always looked at these as potential early signs of failure so replaced them to be on the safe side. I would be interested to know what the general consensus is regarding the replacement of leds that havnt failed but slow start.
  • petehall347
    • Jan 2015
    • 4450
    Re: Led Backlight Repair
    trouble i see with them is they are run far too hard from the start . another built in killer of tv.s timed just after warranty runs out . fit new ones and turn brightness down of the back lights .
    service manuals say renew the lot . expensive i know .
    • dskall
      • Oct 2016
      • 2905
      • usa
      Led's are cheap. I would replace any that I suspect as bad
      • triplefour
        by triplefour
        09-13-2023, 10:43 PM
      • DanPoka
        by DanPoka
        02-15-2025, 05:05 AM
      • Comp_Pro
        No Backlight Macbook A1990 820-01041
        by Comp_Pro
        Hello all,
        Am trying to figure out this backlight issue with this A1990 Macbook Pro.
        Tests performed:
        There is no backlight even with a good screen.
        Backlight IC is receiving the correct support voltages.
        Fuse F8400 ok
        Current sense resistor R8400 ok
        Backlight IC is receiving 3.3V on enable pin.
        Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
        Backlight IC receiving 5V from PP5V_G3S
        Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
        I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
        05-06-2024, 10:23 PM
      • cheebster
        iPad Pro 12.9 5th Gen Backlight Issue
        by cheebster
        Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
        Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
        Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
        The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
        Anyone...
        05-20-2025, 09:17 AM
      • canadaboy25
        LG Flatron 24EN33TA No Backlight When Cold
        by canadaboy25
        I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
        I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
        03-07-2023, 12:23 AM
