sharp aquos lc-52xl2e wont power on
  • MrJIM
    • Oct 2017
    • 20
    Hi I have a sharp aquos lc-52xl2e tv when I plug it in the green light comes on and goes straight to red light then no lights, all this happens within 10 seconds and nothing will happen unless I remove power plug and wait a couple minutes then if I try again the process will repeat . I am unable to go into service mode in this time frame and was hoping this problem is known by someone on this site
    Thanks.
  • maxvalutech
    • 804
    • australia
    Re: sharp aquos lc-52xl2e wont power on
    Well it is a problem often seen on numerous sets and the fix is to remove the back and check for voltages the first being the big main capacitor on power section usually marked "hot" using a dmm set to dc high range with black lead on negative leg and red on positive leg of that capacitor/s. Keep self clear of that section as you test. A few good clear pics of the board/s in the set posted with result of this test will start good responses.
    • MrJIM
      • Oct 2017
      • 20
      here are a couple pictures could you point out what caps you mean please
      • MrJIM
        • Oct 2017
        • 20
        i took the main board out to look at the back as no access to the bigest caps from the front
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          The main Filter cap/s would be the large ones under the metallic shield in pin #1.
            What you need to do first is to report the DC Voltage readings of the connectors on the cold side, you MUST report in the format that shows the pin name and follow by the Voltage reading in TV off mode and when TV is turned on.
            • MrJIM
              • Oct 2017
              • 20
              I am not sure what connectors on the cold side you mean could you explain what connectors you mean please . And I cant access the big caps under the metal plate when the board is fitted to the tv to test with power on . if you could explain it as if I have not got any experience it would really be appreciated
                https://www.badcaps.net/forum/attach...0&d=1509540477
                See that wide white hatched line in the middle of the board?
                The right side is the HOT DEADLY SIDE that you do not want to make any contact with your body, the left side is the cold side.
                • MrJIM
                  • Oct 2017
                  • 20
                  Thanks for explaining that so I will refit the board and with my dmm on dc and my black lead on the big metal sheet of the tv I will test all cold side connectors and report pin number and volts with tv unplugged and tv plugged in. please tell me if this is correct and thank you for your patience
                    Yes.
                    • MrJIM
                      • Oct 2017
                      • 20
                      pin / power on / power off
                      LNB / 0.000 / 0.000
                      LNB CONT/ 0.000 / 0.000
                      PS_ON / 0.000 / 0.000
                      AC_DET/ 3.166 / 0.000
                      PNL_POW / 0.000 / 0.000
                      SGND / 0.000 / 0.000
                      BUS5V / OL / 0.000
                      UR15V / 0.000 / 0.000
                      0.000 / 0.000
                      SI5V / 0.000 / 0.000
                      0.000 / 0.000
                      PNL12V/ 0.000 / 0.000
                      0.000 / 0.000
                      0.000 / 0.000
                      UR60V / 0.468 / 0.000
                      SGND 3 / 0.000 / 0.000
                      UR12V / 0.475 / 0.442
                      UR12V / 0.492 / 0.450
                      UR60V / 0.011 / 0.000
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        You must have some voltage since you say
                        Have you set your meter to read DC voltage.
                        • MrJIM
                          • Oct 2017
                          • 20
                          Hi
                          yes meter set to dc and if i plug the tv in it goes green light red light no lights all in under 5 seconds. I had to disconnect harnesses from a couple of the pins because my probe couldnt fit into the rear of the plug maybe thats why my readings are off ?
                          the readings below were taken with the plugs removed so i could get to the pins
                          LNB / 0.000 / 0.000
                          BUS5V / OL / 0.000
                          0.000 / 0.000
                          0.000 / 0.000
                          0.000 / 0.000
                          0.000 / 0.000
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            Interested in BUS5V OL. You need to move your meter range up one position although BUS5V would indicate to me that it's a 5V supply?
                            • MrJIM
                              • Oct 2017
                              • 20
                              that would make sense as i have no stand by mode, all readings were taken with dmm set to dc at 0.000 range
                              • MrJIM
                                • Oct 2017
                                • 20
                                how can i confirm its the 5v supply and how do i fix it
                                  Are you sure your meter has DCV scale setting for '0.000' DCV scale. Why would the meter have '0.000'V scale??
                                  Typical scale is 200mV, 2V, 20V, 200V, etc,
                                  You are getting 'OL' showing on the meter because it went over the scale for the meter to display.
                                  Show us the pictures of your meter.
                                  Just run the power supply board by itself and then check the 5V standby.
                                  • MrJIM
                                    • Oct 2017
                                    • 20
                                    heres the meter and the setting i used
                                      OK, your meter can be set to Auto range or manually set to the range you want by using the range switch.
                                      So set range to 00.00 and then measure the STBY 5V without power supply board connected to the main board.
                                      You have 5V STANDBY, otherwise you will not have any LED indicator.
                                      I just look at the user manual, you do not have it set to AUTO, you are in the 3.999V scale that is why 5V is showing 'OL'.
                                      '3) The default range is Auto range, and "AUTO" is displayed. Pressing RANGE key
                                      switch to manual range, 400mV/4V/40V/400V/1000V can be selected.'
                                      'Display: 3 3/4digit LCD with a max readings of 3999'
                                      • MrJIM
                                        • Oct 2017
                                        • 20
                                        Do you mean bus5v ? I have 04.98 v dc on that
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
