Samsung LN-T665F
Re: Samsung LN-T665F
Yay figured it out this is what i had to do. i used three 75 ohm resistors to make it work.
first resistor is to be ran from standby to ps_on
the second resistor is to be ran from ground to standby and voila it turns on and all voltages comes up and stable.
i ran another resistor 3rd one on cni-805 Det_5v jumpted to inv-ON/OFF and we have backlights!!!!
Woot so we're good now so clearly the problem is in the main. any ideas where to check there i will start probing around.
So in total you need 3 resistors to force on this TV.Last edited by heavymachines; 10-20-2017, 11:34 AM.Comment
So if i may folks pick your brains. What could be causing the ps_on to be unstable?
1. Thinking caps is one possibility.
2. Bad regulator.
3. Don't think it would be processor or any of the Bga.
4. Not sure what else lol.Comment
'i ran another resistor 3rd one on cni-805 Det_5v jumpted to inv-ON/OFF and we have backlights!!!!' This one does not make sense because DET_5V is the error signal to tell the main board if inverter, backlights are working or not.Never stop learning
isn't it technically overriding? it did work. If there is an error or something bad on inverter it wouldn't go right? or is it possibly forcing on bad cfl bulbs? if so i should probably watch it longer see if its flickers or pink. I don't know.
It did output touch over 5 volts at Det_5v if that means anything. just borrowed it's voltages to inv_on/off.Last edited by heavymachines; 10-20-2017, 09:30 PM.Comment
I have stable voltages at all connectors at power supply when forced. all within reason no jumps that i seen but for extra measure i will double check in longer time span.Comment
You should be able to use resistor between INV ON/OFF and the standby Voltage to turn the inverter on.Never stop learning
Ok that will require a wire as well its got some distance between connectors, i will do this route.
Edit: instead of using wires i'll just jam resistor from it's own wire harness better idea. save from looking for wire.Last edited by heavymachines; 10-20-2017, 09:37 PM.Comment
At this point I would not worry about forcing on the backlights, it's the main board that you will have to deal with at this point.
You are in the same situation as the other TV with main board problem, if you can hook everything back up except the PS-ON, the Inverter on wires and then just leave the resistors in place. If other functions of the board are OK then you should have image and sound and all other functions.
Same thing as in this thread: https://www.badcaps.net/forum/showthread.php?t=65258Last edited by budm; 10-20-2017, 11:26 PM.Never stop learning
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by cheeky2This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
Assuming...7 Photos -
by MtnManMikeHello,
I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
When I plug the TV in, the screen flashes on and off and... - Loading...
