Samsung LN-T665F
Re: Samsung LN-T665F
Yay figured it out this is what i had to do. i used three 75 ohm resistors to make it work.
first resistor is to be ran from standby to ps_on
the second resistor is to be ran from ground to standby and voila it turns on and all voltages comes up and stable.
i ran another resistor 3rd one on cni-805 Det_5v jumpted to inv-ON/OFF and we have backlights!!!!
Woot so we're good now so clearly the problem is in the main. any ideas where to check there i will start probing around.
So in total you need 3 resistors to force on this TV.Last edited by heavymachines; 10-20-2017, 11:34 AM.Comment
So if i may folks pick your brains. What could be causing the ps_on to be unstable?
1. Thinking caps is one possibility.
2. Bad regulator.
3. Don't think it would be processor or any of the Bga.
4. Not sure what else lol.Comment
'i ran another resistor 3rd one on cni-805 Det_5v jumpted to inv-ON/OFF and we have backlights!!!!' This one does not make sense because DET_5V is the error signal to tell the main board if inverter, backlights are working or not.Never stop learning
isn't it technically overriding? it did work. If there is an error or something bad on inverter it wouldn't go right? or is it possibly forcing on bad cfl bulbs? if so i should probably watch it longer see if its flickers or pink. I don't know.
It did output touch over 5 volts at Det_5v if that means anything. just borrowed it's voltages to inv_on/off.Last edited by heavymachines; 10-20-2017, 09:30 PM.Comment
I have stable voltages at all connectors at power supply when forced. all within reason no jumps that i seen but for extra measure i will double check in longer time span.Comment
You should be able to use resistor between INV ON/OFF and the standby Voltage to turn the inverter on.Never stop learning
Ok that will require a wire as well its got some distance between connectors, i will do this route.
Edit: instead of using wires i'll just jam resistor from it's own wire harness better idea. save from looking for wire.Last edited by heavymachines; 10-20-2017, 09:37 PM.Comment
At this point I would not worry about forcing on the backlights, it's the main board that you will have to deal with at this point.
You are in the same situation as the other TV with main board problem, if you can hook everything back up except the PS-ON, the Inverter on wires and then just leave the resistors in place. If other functions of the board are OK then you should have image and sound and all other functions.
Same thing as in this thread: https://www.badcaps.net/forum/showthread.php?t=65258Last edited by budm; 10-20-2017, 11:26 PM.Never stop learning
by MtnManMikeHello,
I'm hoping to get some help figuring out how to troubleshoot this power supply board. The television is a Samsung UN75J6300AFXZA, version no. UH03. The power supply board has two model numbers on it, L75S1 and BN44-00723C. As far as experience level, I'm familiar with recapping boards in terms of safely going through the soldering motions, choosing suitable replacement parts, and so forth, but as far as understanding the various functions of each part of these TV power supply boards, I am a rank beginner.
When I plug the TV in, the screen flashes on and off and... -
by captainKKKSamsung Bn4400612b Power Supply issue takes out a new 5A fuse on my Samsung UN50F6300, without any the BL or main board cables connected. Please advise if this board has known issues and fixes. There are no evident fried components and the caps look ok. Nothing unusal on the bottom side of the board under magnification. Is the ICM801CS under that heat sink a known issue? SJ (https://www.shopjimmy.com/samsung-bn...-1473373576096) out of stock, so component level repair may be my best shot. Thanks.
by GoldenmonkeyMy samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
by scottsman76Hi Guys
I Have this Samsung smart tv that needs repair.
with everything connected i get pulsing A5V at the PSU connector. if i unplug the main board then all voltages pulse on the output connector.
I dont get any voltage on the LED connector.
there is also an audible click around the mosfet marked below
The connector to the Buttons all voltages pulse (3v)
I have searched and found a similar problem but there was a stable 14v, but was also not repaired.
I checked and replaced the mosfets with no effect.
Any ideas where... -
by macesHello everyone,
I have a problem with the power supply of my Samsung PS60E6500.
The LED of the TV is blinking and it doesn't turn on.
After checking the power supply I noticed that the PCB board is burned at QP804 (K13A60D), the MOSFET is shorted.
RP812 is also defect. Unfortunately the resistor is burned so I cannot read the value. Also QP805 and QP806 are shorted. Does anybody have a schematic diagram or does anybody know the type of the parts?... - Loading...
