Panasonic LED TX-40AS640E no video w/ B.L. and sound
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4409
    • Italy - Milan
    Hi to all, i have picked locally this smart 3D tv, unfortunately no remote for the moment , i have ordered it so no service functions now, i have tested only the tcon since i think the prob. is between it and the panel, it lacks some basic voltages, AVDD, VON, VOFF (alias vgh,vgl), the panel brand is unknown to me, Briview and tcon has the main chip by Samsung, also the card code remembers me a little those Samsung codes... the stepup for avdd is supplied trough a six-terminals/3-tracks component, surely a mosfet switch, but the 12v at the drain/source dont passes to source/drain apart probably for an instant at the start when i see about 3,3v on the output cap for the Avdd(with a DMM). Then, since i suspected an abnormal draw on the tcon itself or the panel, i have disconnected the panel, same thing, then short- circuited the mosfet and 12v are on the Avdd output cap but no smoke anywhere. Testpoint for Vcc 3,3v and 1,2v measures good and also the output of the 1117-adj chip (1,8v as marked on pcb). I have suspected a pulled down i2c but it measures 1,5v both clock/data. Connecting output ribbons one at a time makes no difference. What to do now taking in consideration i have bought only 1 board for all my tv's repairs and i dont liked to do it...
    Thanks verymuch Bye.
  • tomartronica
    • Mar 2013
    • PORTUGAL
    Re: Panasonic LED TX-40AS640E no video w/ B.L. and sound
    Hi, did you solve this issue with this model ?
    I have exact model, no picture, backlight ok, TCON replaced but still no picture
    Maybe mainboard ?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4409
      • Italy - Milan
      Faulty screen, must remove diodes one by one on small boards to see if it get better, you can use the Samsung panel trick to jumper trdy-1 and trdy-3 on tcon to disable protection
      • hugocarmo
        Panasonic TX-24A1UN CRT Sound and Input problem.
        by hugocarmo
        Hi.
        I´ve been given an old CRT from Panasonic, it´s almost new, it was storaged and almost not used since bought.
        It is imaculate inside, almost no dust or debris inside.
        The picture is good, but I have no left sound channel, I tried all the inputs, outputs, even on headphone jack. In AV2 I hear sound from right channel but no image, on tv tuner only right sound channel, the same for AV1.
        So I started to look for a service manual, I found one, and started from the beginning.
        Most of the times the caps are the problem so I orderer all the caps for all boards,...
        04-26-2025, 07:45 PM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • iglitare
        Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
        by iglitare
        i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
        Backlight seems to work, Sound (Setup menu after reset) works.
        If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
        Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
        With my small knowledge i would think at least the cables are good.
        Can this happen because of a bad tcon board?
        Or is it always a bad/shorted...
        09-04-2025, 07:13 AM
      • LEECH666
        Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
        by LEECH666
        Good day ladies and gentleman!
        I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
        This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
        I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
        01-19-2024, 05:46 PM
      • x_orange90_x
        TCL 50S535 bad tcon or panel issue?
        by x_orange90_x
        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
        03-29-2025, 11:02 PM
