Samsung UE40D5500 Flickering Lines Across Top 3rd of Screen
  • fitzy89
    • Oct 2017
    • 9
    Hi all
    Here I have a Samsung UE40D5500 with the top third section of the screen flickering lines. From my brief attempt at troubleshooting I determined it was likely the T-con board producing these symptoms. However, I have replaced the board (model number S100FAPC2LV0.3) with a identical "fully tested and working" board from eBay but the issue is still the same.
    I have taken some pictures of the symptoms and the T-con board. The board pictured is the original one from the TV, the replacement is identical with all the model numbers and codes and is currently fitted in the TV.
    Pictures here: https://photos.app.goo.gl/ncrxAj79X3xUAHBf1
    What should I look at next?
    Kind regards
    Rob
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Samsung UE40D5500 Flickering Lines Across Top 3rd of Screen
    If you disconnect one of the ribbons to the panel do you have a good picture on half the screen and what is on the other half. Reconnect ribbon and repeat. Set off when connecting/disconnecting the ribbon cables.
    • fitzy89
      • Oct 2017
      • 9
      When looking from the rear of the TV, disconnecting the left cable shows this:
      https://photos.app.goo.gl/g8hAbRTlOmgHrS4L2
      And disconnecting the right one shows this:
      https://photos.app.goo.gl/WIOnhQnQifNOjww23
      There is also a very feint flickering diagonal line that flickers from the top-right to the lower-left side, it flickers at the same rate as the top section issue, you can just about see it in the first photo above.
      • fitzy89
        • Oct 2017
        • 9
        If it helps, here's some pictures of the innards and various part numbers https://photos.app.goo.gl/NqwjunFoT0nJp0ii1
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          If it is horizontal (left to right) lines. It is not T-CON Bd as these boards show vertical (top to bottom) lines when faulty. Horizontal lines could be bad panel or T-CON signals not reaching the side tabs and are sometimes fixable applying the 'By-pass' method, but can only be applied if side tab bonds are on the side of the panel.
          • fitzy89
            • Oct 2017
            • 9
            Thanks for the info Andrew. Did you see the pictures where I unplugged each LCD ribbon above, does that help identify the cause at all?
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              I agree but it looks like there is a problem with the left hand side (ooking at the screen from the front which makes me suspect there's a side tab issue on that side. I doubt unlike the 60" and 70" sets that it's fixable by removing the side tabs.
              What do you think?
              • fitzy89
                • Oct 2017
                • 9
                What do you think?
                I have dissected it a bit more and have some more photos for you: https://photos.app.goo.gl/ONC6rlrkM3nI6Gyx1
                There doesn't appear to be any visible side connections on this one, at least not without taking the panel out of it's frame (there's a ton of screws and from past experience I'd rather avoid it if I can). Removing a metal strip from the bottom reveals several ribbons into the bottom of the screen, giving each one a firm downwards push does not seem to affect the pattern or make it better/worse at all so these all appear to be fine. I have also tried to push on all of the edges of the frame as well hoping to nudge any ribbons hidden within but again it doesn't seem to affect the pattern at all.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  I rather think that you have a panel issue but would like to hear what others may think.
                  • bman4
                    • Jul 2015
                    • 210
                    • canada
                    The side tabs are under the plastic frame. Feel them to see if any are unusually hot, You might be able to feel through the frame.Im in the same boat with my samsug but im wondering if you can just remove the problematic one .
                    • bman4
                      • Jul 2015
                      • 210
                      • canada
                      You have to remove all or there will be dark spots. Caution the panel will ne half as bright and reccomend to turn down contast. My contrast was set at 100 by default and was already to bright.
                      Sincerely,
                      bman4
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        I don't know if you can successfully remove the side tabs on the smaller sets without losing the picture completely.
                        • bman4
                          • Jul 2015
                          • 210
                          • canada
                          You right just make sure they are on both sides.
                          • fitzy89
                            • Oct 2017
                            • 9
                            From what I can see there is a metal bezel that surrounds the entire panel which is held in place with many screws about every 4 inches apart. Is this the bezel that I need to remove to get to the tabs that you mean? I'm not sure if these panels are anything similar to a laptop screen but if I remove this bezel, will the screen separate into several plastic layers?
                            Thanks for everyone's help so far, I appreciate it
                            • bman4
                              • Jul 2015
                              • 210
                              • canada
                              yes, just lay it on its back with blocks , some tvs are just the plastic.
                              did you confirm with the disconnecting of one side of the t-con.
                              it might not be a shorted side tab but a loose connection if you cant find a hot one try playing with the to induce or reduce symptoms.
                              • reessi
                                ACER BM320 Monitor - Horizonal Flickering Lines After a While
                                by reessi
                                The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                                They are black on the right and gradually fade to nothing on the far left.
                                They start either after 5 mins or up to 2 hours after so annoying for testing.
                                They flicker continuously very fast! With a slight pause milli-second every second.
                                Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                                I tested each half by removing the first the left flex from...
                                06-03-2025, 09:58 AM
                                09-07-2024, 05:50 AM
                              • mrsith
                                Samsung UE70TU7100 - flickering horizontal lines
                                by mrsith
                                Hello again good souls.
                                Got an UE70TU7100. The TV starts up just fine, but right hand side of the screen is horizontal striped a bit, and there are some flickering horizontal lines on the whole length of the screen. I've seen similar static horizontal lines sometimes, when applying the cut tape method and covering wrong number of pins.
                                I've cleaned every connector with ipa, tried cut tape method on main LVDS ribbon as well as small ribbons, connecting the panel boards at the bottom. Tried squeezing the bezel and playing around COFs, but no reaction at all. COFs and...
                                02-13-2023, 05:36 AM
                              • Rubenlily
                                Samsung QE50Q67TAU - horizontal lines
                                by Rubenlily
                                First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                I'm no expert but I've done the tape...
                                08-16-2023, 01:12 PM
                              • jeyoung12
                                Samsung QN50Q60t lines on screen
                                by jeyoung12
                                Hi all
                                I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
                                My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
                                This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
                                It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
                                So....i don't know what end of the C ribbon to work with...
                                02-26-2024, 10:38 AM
