What's the voltage range in video signals?
  • Logistics
    • Apr 2007
    • 721
    Such as over RCA cables, whether it be composite or component, S-Video, whatever, what is the voltage range of a video signal. I ask this so I know what the max voltage would have to be on capacitors in video output stages.
  • i4004
    • Oct 2006
    • 2029
    Re: What's the voltage range in video signals?
    1Vpp or less.
    • Wizard
      • Mar 2008
      • 2296
      yes. very small and very high impendance and terminated with 75ohms usually as well in some cases.
      Cheers, Wizard
      • Logistics
        • Apr 2007
        • 721
        Thanks guys! So the caps do have to be able to support high-frequency as well, correct? I remember reading a white-paper on an s-video filter that talked about how these days electrolytics were more than capable of this application. Although, it sounds like polymers are an even better choice; perhaps that even being what they were referring to. Any other suggestions for capacitors in video-out stages?
        • i4004
          • Oct 2006
          • 2029
          composit and s-video go up to 5mhz.
          component dunno, check wikipedia etc.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • jaroslav.psenicka
            Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
            by jaroslav.psenicka
            I have a Lenovo Yoga 13 Panasonic here, when powered
            • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
            • most voltage rails seem OK (see image below, red labels)
            • resistnace to ground mostly seem OK as well (blue labels)
            the only suspicious is the 0.0V rail (2nd from left, top row)
            • the resistance to ground is rather low (1.9ohm)
            • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
            also tried new BIOS, no change
            I can't find a schematics for the board - can some of you gurus look at the voltages?...
            05-02-2024, 05:59 AM
            LM358 LM358S-13 Datasheet
            The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
            Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
            10-07-2024, 04:12 AM
          • Fernon@Repair
            Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
            by Fernon@Repair
            i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
            VCCIO voltage ok
            VCCSA Voltage OK
            VCCPLL Voltage OK
            Ram Voltage ok
            RamVTT OK
            VPP 2.5 OK
            But No Core Voltage
            and i want to this vrm ic datasheet or pinout (ISL69269)
            anyone have this ic pinout voltages?...
            06-25-2025, 07:19 AM
            MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
            The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
            Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
            10-23-2024, 03:23 AM
