Vestel 17MB82S Only backlight
  • Andreasbest
    • Aug 2014
    • 1172
    • Hellas ( Greece )
    Hello.
    I got a 17MB82S that give me only backlight, no picture and no sound (not sure about sound as i cannot see if the screen is in HDMI,TV,Scart or USB) no OSD at all too.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Vestel 17MB82S Only backlight
    Have voltage to t-con?
    • Andreasbest
      • Aug 2014
      • 1172
      • Hellas ( Greece )
      Hello.
      Really sorry for the delay, i forgot the whole tv and today i remember it!
      Yes i have voltages like 3.3v and 1v. I can write you all voltages at all pins if you want.
      Thank you very much!
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Voltage to T-CON means to ask if you have 12Vdc supply voltage to the T-CON Bd. Look at the T-CON Bd. at the bottom of the TV near to where the FFC from the Main Bd. enter the T-CON Bd. There should be a fuse to measure that you have voltage on both sides.
        • Andreasbest
          • Aug 2014
          • 1172
          • Hellas ( Greece )
          Yes fuse has voltage (12v) on both pins.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Having the exact same issue....any ideas ? Will try reflashing the firmware via USB just for the heck of it...not like anything can go worse than it already is...
            Wattevah...
              If you have USB to RS232 cable you can check the UART debug output on the SCART port, some of the pins are connected to the TV's Linux kernel debug UART.
              • Andreasbest
                • Aug 2014
                • 1172
                • Hellas ( Greece )
                So the problem is clearly in mainboard?
                  No, there's a chance the panel could be bad as well.
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    • Romania
                    +1 - most likely faulty panel
                    Wattevah...
                    • Andreasbest
                      • Aug 2014
                      • 1172
                      • Hellas ( Greece )
                      How can i be sure before the order of the replacement board?
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        • Romania
                        Well if it appears to be responding to the remote, I'd most definitely say it's a faulty panel, though it would be nice if you could confirm by "asking" the TV if everything's alright via some sort of interface like someone around here suggested, though I haven't got a clue how you could achieve that without an RS232 interface actually present on the 17mb82s....perhaps someone knows a clever trick or workaround for the purpose....
                        Wattevah...
                          17MB62 is similar, I believe
                          The UART is on pin 10 (TX) and pin 12 (RX). You may need to reverse RX and TX on your UART device. You will also need to connect to the ground of the TV, on pin 4 and 5 for instance, or the chassis.
                          Make sure to use a 3.3V or 5V UART, not a proper RS232 level device with +/-10V levels which may be fatal to the TV CPU.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            • Romania
                            How about the CH341 I use for flashing EEPROMs ? I have successfully used that in the past for serial purposes so it should work
                            Wattevah...
                              CH341 on its own should work.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4333
                                • Italy - Milan
                                Why CH341 should work? I haven't read it has rs232 comm port on it..
                                I have bought it by ebay but the only info i have is a little specs list on the ebay listing, daoes anyone have a source for the full use of it? That there is something not clear..
                                thanks..
                                • Dannyx
                                  CertifiedAxhole
                                  • Aug 2016
                                  • 3912
                                  • Romania
                                  thanks..
                                  I have successfully used the CH341 to communicate via serial with a router, so I know it can be done. You just have to make sure it's in serial mode and not SPI mode. This stumped me a lot when I first tried it, since despite all sources claiming it CAN do serial interfacing as well, I couldn't get it to show up as a COM port....until I eventually discovered what the little jumper cap on it was for: removed it and I was now in serial mode. The physical layout will differ based on what programmer you get, but the chip itself can do serial via RX/TX....quite versatile IMO.
                                  Wattevah...
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4333
                                    • Italy - Milan
                                    Thanks for the info and sorry for this OT but if anyone can link to me a page with an user manual i thank him very much 'cause i have a Security Alarm Control Panel board with an ATMEL 24C64AN that doesn't answer to the read function by the programmer.. i have to discover installer code, and there are no indications on what is there for the jumper cap.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      https://onetransistor.blogspot.co.uk...schematic.html
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4333
                                        • Italy - Milan
                                        thanks for the info, the jumper meaning is now clear, i found the reason why my ATMEL chip it doesn't read, it works only at 5vcc, i powered it externally and reading's ok and found the installer's code! I'don't know why there's no jumper for 5v/3v selection, i will try to modify that..
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • Raulnn
                                          Ansonic 32HD1 Vestel 17IPS11 17mb55 no Sound, no backlight, no images
                                          by Raulnn
                                          Hello! I am new to electronics, and this forum is fantastic. I have the following problem, I have an Ansonic 32HD1 tv, a generic brand from Vestel, with a 17IPS11-R4 power supply and main 17mb55.
                                          The tv has no backlight, but it also has no image and sound. when it turns on the standby light blinks several times, and there is a very short flash of the backlight, as if it wanted to start, but it does not start. I have measured the voltage on the red wire of the backlight, as you have seen on the forum, and in standby it has 30v, and when it turns on it goes up to 100v and slowly drops...
                                          11-15-2022, 03:02 PM
                                        • triplefour
                                          TCL 75S421 has sound but no backlight not even a flash
                                          by triplefour
                                          TCL 75S421
                                          PSU BOARD: 40-L402H8-PWD1CG
                                          it shows not even a flash of backlight when powering up.
                                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                                          with mb connected, PSON...
                                          11-17-2023, 09:54 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
