LG 32LH3000 stuck in standby (needs dump?)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. I was wondering if perhaps someone could provide a bit of help with this LG TV which is stuck in standby: red LED is on, but that's it. It doesn't respond to the remote or the buttons on the side. It doesn't even TRY to turn on, which would indicate a PSU issue, so I believe the main board, an eax60686902 is faulty since it's not sending the ON signal to the power supply. Couldn't find a dump for this model yet, though I will keep on searching. If someone had this issue before and could provide some tips and perhaps a dump to try and flash it with, it would be great Cheers.
    Wattevah...
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 32LH3000 stuck in standby (needs dump?)
    Is this any good.
    http://www.elektroda.pl/rtvforum/topic3345383.html
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Originally posted by dick_barton
      It may be good, but I have no way of writing that, since I don't have a flash programmer. I'll hang onto it nevertheless just in case I'll ever need it further down the track. I was after a BIN file that goes onto the flash SPI chip.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        I just found something very interesting which I'm very jazzed about and I'm actually going to try it Check it out here. A guy from my country came up with this funnily enough.....the more you learn....
        Wattevah...
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Let us know how it works out.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Now just have to find and dust off an old XP machine and dig out some DB9 cables from the junk box....this should be fun
            Wattevah...
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              Unfortunately no, it didn't work the least bit: I'm not even able to connect, so either I'm doing something wrong or there's something dead on the main board. Replacing the board is the only solution.
              Wattevah...
              • Dannyx
                CertifiedAxhole
                • Aug 2016
                • 3912
                • Romania
                This reminds me of a Samsung set I once worked on where the board didn't show any signs of life but no visible damage either....that was until I replaced the board and out of curiosity removed the heatsink from the CPU only to find a hole blown in it, so it could very well be the case here....
                Wattevah...
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  Having ordered a replacement main BD for this TV I thought I'd dig into this one just for fun to see if I can find anything dead or shorted and sure enough, following along with a schematic, I traced a short on the 3.3v bus down to the CPU itself which perfectly explains why it's dead and burried....very common and have had this same exact issue before.
                  Wattevah...
                  • toty79
                    Hisense LTDN50K220WSEU stuck in standby
                    by toty79
                    Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                    As per Hisense tv title LTDN50K220WSEU stuck in standby
                    PSU rsag.820.5687 HLL 4855WF
                    Main rsag 7.820.5842
                    I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                    05-01-2022, 04:39 PM
                  • lego1234567
                    LG 32LB1R - stuck in standby mode
                    by lego1234567
                    Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                    What could be the problem ? Thanks...
                    01-21-2024, 03:39 AM
                  • Stunt
                    Hp Laptop Stuck on Hp protected by hp sure start screen
                    by Stunt
                    Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                    I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                    I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                    Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                    screen that's it and stuck there. I left it until the following day and i still...
                    09-02-2025, 01:51 PM
                  • Ahari
                    by Ahari
                    I...
                    08-13-2025, 06:12 AM
                  • Rusenga
                    Samsung UA39EH5003R Stuck on standby
                    by Rusenga
                    Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                    Connector CNM803:
                    TV ON
                    Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                    TV OFF
                    Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                    09-18-2021, 11:51 AM
