Panasonic TC-55CX400U - stuck on logo
  • g20zoom
    • Sep 2017
    • 13
    Sad to say...after 1 year, this TV is no stuck on the "PANASONIC" logo screen upon power up.
    Is there any hope for saving this? Is there some kind of hard reset I can do or does it need some kind of new board?
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-55CX400U - stuck on logo
    1 year old? Contact Panasonic , surely they can help under warranty.
      Argh! Another "Not Panasonic" sold as a Panasonic.
      You are unfortunately a victim of Panasonic rebadging cheap sets as their own to cut costs. You will almost certainly find the issue is cheap NAND flash memory which has failed. Replacing the main board is likely to fix the issue.
      I can't be certain, but this should be compatible. Have a look around for other sets as well.
      https://www.ebay.com/i/322765368785?rt=nc
      I am assuming your set is powering onto the logo and staying on that. If so, then it is the main board crashing as it tries to boot the rest of the software. Corrupted NAND flash, due to the use of very cheap flash memory devices, is causing the set to die in the middle of the boot-up process. These TVs are embedded computers, and they usually run Linux of one form or another.
      • g20zoom
        • Sep 2017
        • 13
        My dad went cheapie with this brand. It's over 1 year so no more warranty. He even paid for a service call a year ago, but never told me about it so I have no idea what they diagnosed. Frustrating but he's pretty old now. He bought it from Fry's but lost the receipt, and being such a pain to get it again, then use the credit card maybe for the 2nd year of warranty, I figure I'll just troubleshoot myself!
        More details:
        Upon power up, the "Panasonic" logo is displayed, then the unit powers off within 2-3 minutes.
        I looked at the power supply, and no caps are blown. I can't really tell if any of the caps are raised beyond normal. Hard to say.
        I checked the voltages on the PSU.
        I got around 5V on the +5VSB line to ground.
        I then connection PSON with the +5VSB line.
        I measured 3 other 5V lines, 2 - 12V lines, and in another block, 2 - 24V lines.
        So you think it's the main board? Well I realized it is powering onto the logo, but then shutting down in a few minutes. So I'm not sure is that still pointing to the corrupted NAND flash?
        ebay does have a couple of the mainboards for sale using model # so it seems like I have a way out, until the next one dies assuming it's still the board.
        • ducky29
          • Dec 2015
          • 370
          • Europe
          It might be a firmware problem.
          Here is the firmware
          ftp://54.165.229.211/television/soft...u_firmware.zip
          and the instructions
          • g20zoom
            • Sep 2017
            • 13
            ducky29,
            Thanks for the firmware.
            I powered it up per the instructions with the bin on the USB stick, and it upgraded the firmware, powered off.
            Then it powered up, upgraded firmware again, powered off.
            Repeated again for a 3rd time.
            At this point, I just put the tv face down as I have the back cover off.
            What do you think is going on? Sounds like it's not upgrading but then not sticking to the board.
            I would think if the firmware was really updated, the firmware would be smart enough to not load the same version again. But if the firmware never saves, then maybe there is a mainboard issue?
            • g20zoom
              • Sep 2017
              • 13
              tom66 or anyone else that knows...
              My main board is stamped "CV6488H-A".
              There is also C/N: 890-M00-06NBZ
              Since this is rebadged...this board can be bought as a Westinghouse, Elements, or Panasonic. Do you know if it's ok to use any brand? Or will the specific firmware mess things up?
              Also, someone on ebay does have the same board but it's for the Panasonic 50 inch version. ie TC-50CX400U
              Can I use this board and maybe just reload the firmware?
              • dskall
                • Oct 2016
                • 2905
                • usa
                If boards are the same then they should work but you will probably have to change remotes.
                  This is the pain, Panasonic normally makes good products, and up until recently did not rebrand anything! So you cannot blame your dad for picking up what is ostensibly a Panasonic television knowing that they normally make very high quality sets.
                  They seem to have tried it recently in the UK and the US with these cheap TVs - probably so they can be more competitive - but they have discovered what Sharp's pain was when they did this, which is that customers lose trust in your brand, and this long term loss is far better than the short term gain of selling a few more TVs a little cheaper.
                  It should be okay - but the brand will appear differently when the set powers up. This shouldn't be a problem. Some settings and options may be different. It is likely that all the sets are made with the same panel, but it is possible they are not, if so, you may have some compatibility issues with the image on the screen. If this occurs, you will need to return the board until you find a compatible version (make sure you order from a company that supports returns.) Most of these cheapie sets use the same panels so you should be okay here. As dskall says there's a chance the remote will be different as well.
                  • g20zoom
                    • Sep 2017
                    • 13
                    Thanks guys for all the tips. It's amazing what you can learn from here.
                    That's true...we had many great Panasonic things in the 80s and 90s from them. Shame they are cutting costs like everyone else.
                    I would prefer to Keep the Panasonic logo(makes the wife happy) and use the correct remote I already have.
                    Looks like I have a few options:
                    1. wait for the exact Panasonic board for the 55" to show up on ebay
                    2. Use the same board model # and version, from ebay but it's for the smaller Panasonic 50" tv. Same TV series though. HOPE that when I reload the 55" firmware for this TV, all is good.
                    3. Use same board model #, version but for a DIFFERENT brand TV. Those boards are readily available from westinghouse, seiki, element, and even kenmore. In theory these should work too, but I'm not sure it will take the Panasonic firmware. Depends if the SW does some kinda of check or is it just looking for any *.bin file. It might be even looking for a naming convention of the file differently then what Panasonic would do. These boards are cheaper but it seems a little too risky of an approach.
                    I'm getting anxious since this TV is dissected on our living room table...so gotta try something soon. It's great that some ebay sellers have returns but yes, typically the restock free + return shipping.
                    • dskall
                      • Oct 2016
                      • 2905
                      • usa
                      Changing firmware from one brand to another is not as easy as updating from usb. It would take removing the eeprom and reprogramming
                      • g20zoom
                        • Sep 2017
                        • 13
                        Thanks for that info. Very good to know I can't just swap brands with a new bin eeprom file and a usb reboot.
                        What do you think about using a Panasonic board for a different size tv, same model series, same main board, but reflashing using the bin file for my exact size/model ?
                        Anybody know about replacing the NAND flash/eeprom?
                        Do you have to remove, copy contents to new chip, then resolder new one in?
                        And if the nand has failed to write presumably, can you still copy it?
                        I'm sure more trouble then a new board but I can probably find a person to solder smt at work. But the copy part I'm not sure about.
                        • g20zoom
                          • Sep 2017
                          • 13
                          TV fixed!
                          Since Seiki is the OEM manuf. for this Panasonic TV, I went with the 55" Seiki mainboard with the same board/version number after consulting with my firmware friend(doesn't do TVs but just to get an idea how these things work). Turns out the Seiki board had one less USB port, which I missed in the pics, but it still had the usb 2.0 port, so all was good.
                          It powered up with the Seiki logo, and all seemed to work fine. I didn't have a remote...nor a universal one, so I said what the heck..and I used the Panasonic firmware for my TV. The firmware upgraded, it rebooted in a color check of green/white/red/blue/etc...and kept cycling! slight panic mode, but I powered off and removed the USB with firmware. Rebooted, Seiki came up, but when I went to the menus, it's now Panasonic. Plus my Pansonic remote worked too.
                          Anyways TV is working great now!
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            Good to know. Didn't think you could change brands from usb
                            • x_orange90_x
                              Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                              by x_orange90_x
                              I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                              12-28-2023, 06:26 AM
                            • G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                              by G33RT
                              Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                              It does power up when pressing the power button.
                              I already try the power button while plugin the plug with no result.
                              Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                              Could this be an PSU or eMMC issue ?
                              07-19-2025, 03:43 AM
                            • justice171
                              JVC LT-50N795 Stuck on Wisdom Share Logo
                              by justice171
                              I'm working on a JVC TV for a client that's stuck on the "Wisdom Share" logo screen.
                              It's a model LT-50N795 with a board number TP.HV510.PC822. I attempted a firmware update via USB, and while the upgrade was completed successfully, the TV is still stuck on the Wisdom Share screen on reboot.
                              Has anyone encountered this issue before, or does anyone have any suggestions on possible solutions?
                              Thanks in advance!
                              11-04-2024, 02:55 AM
                            • mr.Data
                              Macbook A1990 stuck on logo
                              by mr.Data
                              This Macbook Pro 2018 boots up and then gets stuck on the logo.
                              All the normal methods of resetting this Macbook have been tried but do not work.
                              I cannot get into recovery mode and there is no bar displaying, it's just the white logo on a black background.
                              Any help would be greatly appriciated....
                              04-18-2024, 11:51 PM
                            • digtalhd
                              Dell Inspiron 7490 Stuck on Dell Logo
                              by digtalhd
                              Hi!
                              Anyone hepl me! My laptop stuck Dell logo after I clear ME.
                              Dell Inspiron 7490
                              S/N: 28760285127
                              LA-H451P Rev: 1.0
                              Thank!...
                              11-13-2024, 10:17 PM
