Element ELCHS321 Comes on then buzz and picture flicker
  • Doc38343
    • Apr 2015
    • 402
    Element ELCHS321 Comes on then buzzes and the picture (menu and all) starts flickering off/on rapidly.
    As soon as i got the back off i saw the trouble but then decided it was too good not to share this one....
    Classic Bad Caps.
    Clue is on the power supply and the obvious swollen small caps i thought at first... then I saw "IT"... LOL
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Element ELCHS321 Comes on then buzz and picture flicker
    Quite a few capacitors in extremely bad conditions. Hope replacement capacitors sort it out.
    • Doc38343
      • Apr 2015
      • 402
      Yup the big filter cap in the middle was vented to meltdown....
      Replaced all the caps and VIOLA!!! Back in action!
      not familiar with element brand but this thing is built like a tank..
      Just cheap caps but it is pretty solid otherwise.
      Date stamp is 2008
      went up on the voltages of the caps a wee bit just to keep er cool..
      Done
      • Tr0ll
        by Tr0ll
        Original T-con:
        First replacement T-con:
        10-07-2023, 07:48 PM
      • fixit007
        Samsung flicker - BN44-00932T board or else?
        by fixit007
        I picked up this TV that the prior owner said - just died.
        Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
        Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
        Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
        05-04-2024, 06:14 PM
      • JJAAMM
        by JJAAMM
        Problem
        07-06-2023, 06:01 AM
      • TR103
        by TR103
        - it keeps rebooting
        01-22-2025, 04:12 PM
      • EazyBone
        Element E4AA70R black screen shows picture
        by EazyBone
        On this TV I got black screen with with picture.
        Tested the LEDs and they work.
        Had a hunch that this was similar to a ONN tv thread I found and wanted to post about this to possibly help someone else.
        The capacitor by the LEDs is bulging, 450v 10 uf. I suspect this is the cause. Will post results after replacing the capacitor. You could just replace power board as well I assume.
        https://www.badcaps.net/forum/showthread.php?t=110615
        Will post results when capacitor arrives...
        10-13-2023, 05:07 PM
