Sharp LC-55UB30U giving me brain damage
  • brucetv
    • May 2015
    • 281
    • united states
    I have this Sharp LC-55UB30U in the shop and it doesn't want to Power up, show a stand by light, no backlights, no sound but all my normal voltages seem to be present.
    Power Supply part # 0500--0605-0910
    Main Video Board # 3655-1112-0150
    T-Con LJ94-32662F
    Power Supply
    CN102
    Pin 1-3 5v stby 5.246 5.24
    Pin 4-6 12v 12.25 12.25
    RMT On 4.938 4.93
    BL On/off 0.110
    Dimming 0.399 power on 0.387
    Dimming 0.399 0.386
    Main
    U32 in 5.2 out 3.26 adj 2.06
    U27 in 3.4 out 1.82 adj 0.58<-----adj too low?
    U17 pin 1 12.24v
    U20 pin 1 1.513v
    Tcon Fuse both sides off 0.495v on 0.525v
    Tv standby light does not light up at plug in and no optical led on at power up, just dead. I couldn't find the same Main Video Board but Encompass said they had a sub so I ordered it and it looked identical and fired the Tv right up...except for one BIG problem...the picture was upside down and there was no way to get into the service menu trying 3-4 methods so we determined the Main was the wrong version as this Tv is very version specific. The picture looked great, but nothing in the menu or remote to flip the picture like some Sharp's I've seen. Do you think that U27 Volt Reg adj is too low and maybe suspect? Marking look like reverse C 11 5NC 1117. Can't seem to find the same one in digikey or mouser. Anybody have any suggestions?
  • R_J
    • 9535
    Re: Sharp LC-55UB30U giving me brain damage
    LM1117 https://cdn.badcaps-static.com/pdfs/...bb102c88cc.pdf Digikey has them
    • brucetv
      • May 2015
      • 281
      • united states
      Thanks RJ...I've got some of these in the box...do you think they will work? Thanks for the part #....my poor eyes are worn out
      https://www.digikey.com/products/en?...ST33T3GOSCT-ND
        Vref 1.25 + Vadjust = Vout
        So 1.25Vref + 0.58Vadj = Vout 1.83V
        So there is nothing wrong with U27.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          1.8v is a common logic voltage, so i would not view it as suspect from that point of view either.
          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
          • dskall
            • Oct 2016
            • 2905
            • usa
            BL_ON .110v ?
              HP 210 SFF E3-1225 Specification for Upgrade or Repair
              This specification for the HP 210 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 210 SFF boardview and 210 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP 210 SFF is accurate,...
              09-12-2024, 03:30 PM
              HP Z210 SFF E3-1225 Specification for Upgrade or Repair
              This specification for the HP Z210 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z210 SFF boardview and Z210 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z210 SFF is accurate,...
            • advant
              by advant
              02-03-2020, 12:25 AM
            • sefoster
              Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
              by sefoster
              I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
              11-20-2022, 09:29 AM
            • gavenb
              Sharp LC-80LE661U 80 inch
              by gavenb
              Hi folks!
              I have a LC-80LE661U that had some interesting issues.
              Initially, it would come on and show the sharp logo and would show normal static before shutting off.
              I started troubleshooting by disconnecting the led lighting strips and turning it on. It would do the same thing - come on, show the sharp logo and shut off. After reading, it was suggested to replace the main board. That was replaced and the same symptoms resulted. After this and some reading, the parts cannon got loaded up. I replaced the power board, same issue. Replaced the Tcon board and now it...
              11-12-2023, 02:05 PM
