LG Smart Tv No picture but has flickering horizontal lines.PLEASE HELP
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: LG Smart Tv No picture but has flickering horizontal lines.PLEASE HELP
    that looks like tab bond failure to me. (bad panel) give the bezel a twist and see if it clears up the picture temporarily.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • budwich
      • Jul 2015
      • 3097
      the "one horizontal line" usually points to a bad tab bond on the side of the panel (or bottom depending on the panel design). It is unlikely to be fixable. IF the panel only has bottom tabs, then you might get lucky by using a "tape block" method which uses pieces of tape on a portion of the tcon to panel cable to block a small area that is causing the issue. The set then may work for a period but it will likely get worse.
      • Ashhad101
        • Sep 2017
        • 16
        • usa
        well luckily my tv has two cables on the bottom can you please tell me more about it how to perform this fix? i will soon upload pictures of my cables
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
        • iglitare
          by iglitare
          09-04-2025, 07:13 AM
        • rstrube
          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
          by rstrube
          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
          Hi Everyone,
          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
          Yesterday, 01:37 PM
        • rstrube
          by rstrube
          Hi Everyone,
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
          Yesterday, 12:19 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
