Samsung tv vertical distortion / black bar
  • neverexisted
    • Nov 2012
    • 76
    I have a 52 inch samsung tv model: LN52A550P3F with distortion on the screen.
    This TV I had fix once before for a no power issue. It was fixed by replacing the caps on the power board. This time its showing video issues. There are two remaining caps that weren't replaced last time that are bulging. I have reseated the ribbon cables going from the video board to the panel. This is an intermittent issue. It may not do it at all for hours and then it will do it constantly.
    I am thinking its a bad panel but I wanted to check here before I call it a lost cause.
    I have read through this thread here: https://www.badcaps.net/forum/showth...t=21648&page=2 but none of the answers have helped the issue (short of replacing the T-con board.
    I have uploaded a video here: https://www.youtube.com/watch?v=E3hw_hlyFdw
    Edit: Also I have tried tapping on it and have not noticed any changes when doing so.
    Thanks for reading people of the internet I appreciate it.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8326
    Re: Samsung tv vertical distortion / black bar
    Did you check for a tab bond issue? What happens if you tap or squeeze the frame around the affected area on top and bottom? Did you clean the ribbon cables with alcohol? What happens if you just have one side of the ribbon cables on the Tcon connected that goes to the screen, then vise versa?
    • neverexisted
      • Nov 2012
      • 76
      I cleaned the ribbons with no change.
      There is only one ribbon that I can see going to the T-con board I uploaded a pic here: https://s26.postimg.org/tdmv9rgqh/21...44183940_o.jpg
      I tried pressing on the edges and I think I did see a change. But its not having the issue now so I will have to wait for it to re appear to test that.
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        the cable that enters the t-con is the lvds cable. cap has asked you to remove the ribbon cable that goes from the t-con to the panel. they are on the top side of the t-con.
        these cables need cleaning too.
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • neverexisted
          • Nov 2012
          • 76
          I will try that thanks. Yeah idk why that didn't occur to me the first time I read that post. I'm having a derp day.
          • neverexisted
            • Nov 2012
            • 76
            Well I cleaned all the cables with no change. There is definitely a change when I press on the back of the panel. So it looks like its the tabs I saw in another post. I have all the necessary equipment. So I guess I just need to figure out how to get to the tabs lol. Wish me luck.
            • attainteddragon
              • Apr 2013
              • 764
              • australia
              i was going to say that it was most likely a tab bond issue, but you need to check all possibilities.
              now, since it is only effecting half of the screen, it could also be a failing ceramic cap on the driver board. it does not happen often, but does happen. you might get lucky.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8326
                Get some thermo pads and put that on top of the tab bond... that's what I do.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4459
                  • Italy - Milan
                  "There are two remaining caps that weren't replaced last time that are bulging."
                  A 52 inch needs more cure than replacing only those bulged, next time until you don't buy an esr meter, replace them all apart the 450v ones!!
                  For the defect (apart the stiff neck :-)...) it don't remember me the typical cases when a tab bond is defective, where you see artifacts like vertical colored bars, it seems only a ribbon connection between tcon - panel that if not dirt at least with some broken traces, so when there's no defect try to push several times the thing until you see the defect. Surely is not the lvds cable to the main av.
                  • neverexisted
                    • Nov 2012
                    • 76
                    I will check that before I tear the panel down. But I have no clue where to start with pulling the panel and I don't want to either take apart whats not needed or break something.
                    • neverexisted
                      • Nov 2012
                      • 76
                      Point taken.
                      I do have a capacitor meter if thats what you mean by esr.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4459
                        • Italy - Milan
                        I have the suspect and i'm not the only, that capacitor are the very biggest cause of failures on tv like theese, so replacing original ones, not the best usually, is a good thing, that's why i've said it, esr meter is better than capacity meter, for what i know. bye.
                        • Ancient1
                          Strange LG TV issue : Image vertical lines in black screen
                          by Ancient1
                          Hi
                          Asking for a friend.
                          I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
                          but here its the opposite !
                          TV has new T-con = same issue
                          A missing panel voltage would have global effect
                          So , what should one do ? how can I find where the fault is ?
                          Thanks !...
                          02-05-2025, 03:37 PM
                          09-07-2024, 05:50 AM
                        • wizard13
                          Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                          by wizard13
                          I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                          I have checked the forum and the available documentation but could not find a solution specific to my issue.
                          • Brand & Model: Dynabook Satellite Pro C50D-B-100
                          • Part Number (P/N): PYU13E-00C00PFR
                          • Serial Number (S/N): 22028896H
                          • System Configuration (SC): A1PYU13E1127
                          • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                          • Power Input: DC 19V –
                          02-28-2025, 02:43 AM
                        • Nairolf
                          Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                          by Nairolf
                          I have a Samsung DM32D display.
                          When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                          Here’s what I have tried so far:
                          1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                          2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                          3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                          From these tests, I suspect the problem might be on the mainboard. Could anyone...
                          08-24-2025, 03:47 AM
                        • vincentedel
                          Samsung SyncMaster 740n Phase Control Issue
                          by vincentedel
                          I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
                          I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
                          04-22-2025, 12:33 AM
