lg 42cs460
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    lg 42cs460
    Hi, customer just brought to my shop lg42cs460, this tv has no standby red light, no power. i checked i found out is from the mainboard, i want to know if anyone has step by step on how to fix this board?
    Hispeck
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: lg 42cs460
    Need good clear straight on pictures of back of tv with cover off and each board.
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      Re: lg 42cs460
      Ok bro. here are the pictures for the tv
      • CapLeaker
        Leaking Member
        • 7976
        Re: lg 42cs460
        Best thing is to check first if you have power on the main filter capacitor.
        We need much better pictures from the PSU, so we can identify things.
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Re: lg 42cs460
          What voltages do you have on the power supply connector?
          • hispeck
            • Aug 2015
            • 258
            • nigeria
            Re: lg 42cs460
            As i speak now, i used another mainboard and it worked fine, is clear that the board is bad and i need way out on how to fix it
            Hispeck
            • mecha1166
              Anyone here fix a tv and customer cracks panel when they get it home?
              by mecha1166
              About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
              03-29-2024, 11:27 AM
            • AccountSaver
              Lenovo Thinkpad E15 Gen 2 NM-D011 - No display ? External , yes!
              by AccountSaver
              Here is a pretty crazy one.
              Step 1.
              Laptop was brought to me as dead not working. Removed everything , cleared everything.
              Step 2.
              Some liquid damage close to the Type - C connector, and the connector even though it was cleaned wasn't charging the battery . Removed the Type-C port, and replaced it. Now the laptop turns on and charges battery. Shows external screen , not internal.
              Step 3.
              Took out the screen and checked it to a secondary Gen 2 i have, screen works like a charm.
              Step 4.
              Lets ,dive into the board. I see the edp cable on the...
              05-07-2025, 07:16 AM
            • master_haze86
              820-01958-A no power sys led = white when charger is connected.
              by master_haze86
              Hi everyone.
              First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
              But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
              A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
              First thing...
              02-15-2024, 05:30 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • cha0swaver133
              HP Zbook 15v G5
              by cha0swaver133
              Hi guys, i need help with identifying IC.
              Customer brought me his notebook after previous repair shop visit. Problem was, his notebook was not charging and unable to start with battery plugged in. So that shop desoldered one IC. Notebook is working on AC, but customer wants fix.
              And i have no idea how to find what that was and i don't have donor board....
              10-13-2022, 12:32 AM
