No voltage cold rail. TCL L39B2610
  • keshin
    • Jun 2016
    • 8
    Hey guys and gals quick warning I'm quite movie and have 3 LCD tvs I wish to learn this new skill on. I appreciate very much any help anyone can give me. That aside here are my symptoms.
    1. The tv does not turn on, no standby led etc
    2. The fuse was blown I have replaced and it has not blown again
    3. I have taken voltages on different places and it appears I'm not getting voltage across to the cold side
    4. No caps appear to be bulging or leaking
    5. No other signs or burnt components or damage apart from pictured below slight deformed frame.
    I'm thinking the problem lies somewhere at this transformer.I get voltage to the hot side but not out the cold side.
    I appreciate any help anyone has to offer I'd like to learn the skills to repair this stuff instead of it ending up in a landfill. The worlds already full of too much waste
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: No voltage cold rail. TCL L39B2610
    if your fuse failed then it is most likely that you have other bad components.
    first, we need pics of the entire back of the tv and a straight on pic of the whole ps.
    you also need to check what voltages are present on the harness that goes to the main board. list as pin no, pin desc, v in stby, v when on.
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • keshin
      • Jun 2016
      • 8
      Thanks for your reply attached are 3 photos one of while back of tv, main power board and then main board
      As I cannot turn the tv on I can only give voltages with the power plugged in
      Pin out as follows starting from top left
      24v = 0v 24v = 0v
      24v = 0v GND = 0v
      GND = 0v GND = 0v
      3.3v = 0v 3.3v = 0v
      PS-ON = 0v GND = 0v
      BL-ON = 0v DIM = 0v
      Last edited by keshin; 08-30-2017, 09:12 PM. Reason: Added picture at bottom of pinout plug that goes to main board
        24v = 0v 24v = 0v
        24v = 0v GND = 0v
        GND = 0v GND = 0v
        3.3v = 0v 3.3v = 0v
        PS-ON = 0v GND = 0v
        BL-ON = 0v DIM = 0v
        Are those Voltage taken with all the cables back in place and measured before and after the power switch is activated (the Voltages after the power switch is activated are needed for us to find out if the main board sends out the command signals or not) ? We need those readings in two states.
        This is an always on power supply so it should have some Voltages on the cold side.
        We also need clear straight shot high res of the whole top and bottom side of the board so we can trace out the connections.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          could you also check the voltage on ce1 or ce2. dcv across either of these caps. be very careful as you are measuring voltages on the hot side of the ps.
          a picture of the underside of the ps will be required too.
          if you can add pics as attachments, (by clicking on advanced then add attachment,) will make things easier to view in the thread and not slow down the loading of page.
          • keshin
            • Jun 2016
            • 8
            With cables plugged in voltages are 0 pushing power button does not change state or anything. Attached is a photo. The red circled section is the high voltage side which also has voltage. The green circled area is the low voltage (cold) side it has no voltage anywhere. The blue circled section starting form the top are as follows.
            All tests on hot side used hot ground
            All tests on cold side used cold ground
            Voltage regulator
            Hot side. Cold side
            Pin 3 =0v. Pin 1 =0v
            Pin 4 =0v. Pin 2 =0v
            Transformer ? (Centre blue circle.
            Hot side. Cold side
            Pin1= 0v. Pin9= 0v
            Pin2= 0v. Pin8= 0v
            Pin3= 321v. Pin7= 0v
            Pin4= 321v. Pin6= 0v
            Pin5= 321v
            3 blue caps
            Hot side Cold side
            Cap1= 0v Cap1=0v
            Cap2= 104v Cap2=0v
            Cap3= 104v Cap3=0v
            Last edited by keshin; 08-30-2017, 10:29 PM. Reason: Corrected readings using DCV readings, and main filter cap negative leg
            • keshin
              • Jun 2016
              • 8
              Sorry what does dvc mean? I'm still new to this. Attached is the back view
                I need pictures as requested in post 4 for me to be able to help you.
                BTW, you are using the wrong GROUND for your meter for those Voltages you report for the hot side.
                No way you can have 482V reading without nice big smoke coming out from the TV, you use wrong ground for the Primary side, the negative leg of the main filter cap in the hot side is the ground ref point for the primary side circuit. Those readings are invalid.
                  DCV = DC Voltage
                  That is good picture, thanks.
                  • keshin
                    • Jun 2016
                    • 8
                    Sorry guys will try again with pictures also not sure if hot side measurements are right in my previous comment I tested with ac on the volt meter
                    Ce-1 = 323dcv
                    Ce-2 = 323dcv
                    Attached to this post is the front view
                    • keshin
                      • Jun 2016
                      • 8
                      I have updated the readings on the post #6
                      • keshin
                        • Jun 2016
                        • 8
                        Any help with this anyone?
                          https://www.badcaps.net/forum/attach...2&d=1504152366
                          Can you read the P/N of that 8-pin SMPS IC on the top left of the picture?
                          Check resistance of the MOSFET QW1 (attached to the heatsink) Source pin resistor R403 to see if it still shows < 1 Ohm or not, it looks like it has blown.
                          Also check the capacitance and ESR of the startup/running cap C424.
                            by momaka
                            03-15-2023, 10:17 PM
                          • HERETIK10
                            MSI GT70 2PE Voltage dropping on the main power rail
                            by HERETIK10
                            I have a strange problem (for me) on an MSI GT70 2PE laptop.
                            When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                            The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                            On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                            I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                            11-24-2023, 06:06 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • jaroslav.psenicka
                            Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                            by jaroslav.psenicka
                            I have a Lenovo Yoga 13 Panasonic here, when powered
                            • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                            • most voltage rails seem OK (see image below, red labels)
                            • resistnace to ground mostly seem OK as well (blue labels)
                            the only suspicious is the 0.0V rail (2nd from left, top row)
                            • the resistance to ground is rather low (1.9ohm)
                            • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                            also tried new BIOS, no change
                            I can't find a schematics for the board - can some of you gurus look at the voltages?...
                            05-02-2024, 05:59 AM
                          • piernov
                            Laptop battery charging circuit
                            by piernov
                            1. Some theory
                            1.1. Introduction
                            Almost every laptop has a charging circuit of some sort, that does a few things:
                            • Manages switching between AC adapter and battery power
                            • Manages battery charging and generates power rail to charge battery
                            There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                            • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                            • Narrow VDC (NVDC)
                            Texas instrument has a nice overview of these technologies with some more details at https:...
                            11-15-2020, 01:31 PM
